Originally Posted by championmayday
I need to do this soon, so no need in droping the pan? and how many quarts to do this?
if you don't plan on dropping the pan and replacing strainer then you could just do a few drain and refills in short intervals (e.g. every weekend).
best if you could drain it, drop the pan (clean it), replace the strainer, put all together with new gasket (use 1/4'' drive torque wrench on all bolts), refill and then flush it with like 10 qts. it would create a nice cleaning baseline.
otherwise (no pan dropping involved) a flush with 12qts of fluid will do some good and complete cleaning too.
plain drain and refill on 4cylinder model (A140E) is like 2.7qts transmission only (plus 1.7qts on separate differential).
plain drain and refill on 6cylinder model (A541E) is like 5qts and that is for transmission AND differential together (they have separate drain plugs, but once you loosen one both get drained pretty much).
