which pistons should i buy??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2010, 12:38 AM   #1 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
3rd Generation which pistons should i buy???
92 camry 5sfe and going to boost it in a few months.
should i get a 8.5:1 or 9.0:1 forged piston?
im leaning towards the 8.5. what you guys think?
project92camry is offline   Reply With Quote
Old 12-16-2010, 12:54 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
9.0:1,
A litttle bit more power while still staying in a safe compression range for boosting.
I'm running 9,0:1 and 18 psi on 93 octane. No problem. Awsome pull.
The Jedi Speeder at CarDomain
Old 12-16-2010, 08:41 PM   #3 (permalink)
I cheated with 7075 Al
N/A Camry Sleeper's Avatar
Gameroom cash: $161600
View N/A Camry Sleeper's Photo Gallery
Really depends on how much boost you will be using - but I agree with MR2Jedi - 9:1 is a pretty good ratio. If you were really ambitious and wanted something a little more aggressive you could get 10.5:1 or even 11:1 and run low <8PSI or so, but water/meth injection is almost required with this plus proper safe tuning, however if you were to suddenly lose power to the fuel pump or water/meth injectors...well, time to start over!
Subscribed ...would like to take some ideas from people using FI for my N/A build, and will be posting my *SLOW* progess as time goes on!
1996 Toyota Camry 5SFE 5-spd 329.9K - UNDER REPAIR
1997 Honda Civic 1.6 5-spd - 183K and 27 MPG average - Dependable DD and *small* family car
1991 Acura Integra 1.8 5-spd - 241K and 28MPG average - I'm game for a simple LS Vtec swap now...
N/A Camry Sleeper is offline   Reply With Quote
Old 12-16-2010, 09:16 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Anything above 9.0:1 is risky. And like stated above, you will have to keep the boost low and take extra steps for charge cooling.
With my set up at 9.0:1, I would not go more than 19psi, And thats if I could find 95 octane. The highest I've found locally is 93, so I keep it at 18psi.
Available fuel in your area should also play in your decision.
Old 12-16-2010, 10:47 PM   #5 (permalink)
View SirThomas88's Photo Gallery
Are we talking about forged pistons?
SirThomas88 is offline   Reply With Quote
Old 12-16-2010, 10:49 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
yes
Old 12-18-2010, 12:04 AM   #7 (permalink)
Pabloso
thanx for the input guys. im only planning for 10psi for now and then going 15psi when i do a 3sgte head swap in the future.
Old 12-18-2010, 12:38 AM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Ah, 5sfte stroker! That can be a beast.!
With a FMIC, you'll be good at 10psi.
I would recommend the ATS Racing 170 degree thermostat. A cheap mod to help keep temps down- especially since the 5s head doesn't have coolant jackets.
Old 12-18-2010, 02:34 AM   #9 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
In case you don't know, there's a difference between the pistons using either 5S or 3S head.
RichieRichJP is offline   Reply With Quote
Old 12-18-2010, 02:38 AM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
If you're talking to me, yes, I know. There's more to the stroker than just the 3sgte head.
5s crank must be machined to accept 3s rods, etc.
Old 12-18-2010, 02:39 AM   #11 (permalink)
I meant to project camry up there^
I don't think he knows the work involved.
Old 12-18-2010, 02:44 AM   #12 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Possibly. I would suggest he does some reading on the build in the MR2 section or at MR2.OC
Old 12-18-2010, 08:05 AM   #13 (permalink)
Pabloso
ahh man really? wats the difference in the pistons? . cause im goin to build the bottom end for now then do the head like in the summer.
Old 12-18-2010, 09:55 AM   #14 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
^ This.
'07 Honda Ruckus Big Bore
Old 12-18-2010, 10:17 AM   #15 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
that head swap is major $$$
