Originally Posted by eaglemtn
Let's say this is where it's leaking. Does this require a water pump removal to replace the gasket? Is there enough give in the water bypass pipe that someone can loosen the connection and put a new gasket in?
There maybe enough give in the water bypass pipe, but i'm not positive. Follow the pipes and see if theres anything holding it down (bolts, screw, etc..) and where the other end of the pipes attach to.
There is a o-ring and gasket on the water bypass pipe.
