a/c problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2010, 09:39 AM   #1 (permalink)
View budweiserdrinker44's Photo Gallery
a/c problem
97 camry 5sfe. as soon as i turn the heat on in the car the a/c kicks on. i push the a/c button and it stays lit. tried swappin out the switch with one from another car. also both fans at radiator click on as soon as i turn on the heat. any ideas?
budweiserdrinker44 is offline   Reply With Quote
Old 12-19-2010, 09:54 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
If your Air Conditioning button is LIT up (Pushed in), both cooling fans will run. They should turn off when the button is pushed out (Released .. Not lit). If it stays lit, I would say you have a wiring issue.
Check your ground wires on the Fan Main relay.
Old 12-19-2010, 09:58 AM   #3 (permalink)
thankyou verry much i will check this out right now/after lunch
Old 12-19-2010, 12:24 PM   #4 (permalink)
unless i checked it wrong the grounds are fine and so are the relays.
Old 12-19-2010, 12:38 PM   #5 (permalink)
So your AC light is always lit up, correct?
Old 12-19-2010, 12:48 PM   #6 (permalink)
Pull your AC Fan relay #2 and check pins 3 and 5 for continuity. If theres continuity your fan relay is stuck open
Old 12-20-2010, 07:00 AM   #7 (permalink)
that makes sense. i will try that today. once again thank you.
Old 12-20-2010, 07:06 AM   #8 (permalink)
you could also check Fan relay #3 (Pin 2,3) and Fan relay #1 (pin 3,4) and Fan Main Relay (Pin 3,4)
To check for proper ground, you remove each relay and probe the following pins (On the car) and connect them with the body, checking for continuity
Fan Main Relay ---- Pin 2 and 4
Fan Relay #1 ------- N/A
Fan Relay #2 ------- Pin 5
Fan Relay #3 ------- Pin 4
