I'd worry about the ATF leak. The diff, if its sump is separate, will run dry and self destruct. If you have a fill plug for the diff, top it off with a high mileage ATF. If not, keep an eye on the ATF level. You need to replace that tranny seal that leaks.
If you're not using a high-mileage oil, do so. It could help slow the leak down.
