Transmission won't shift when cold. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2010, 07:56 PM   #1 (permalink)
View 95Camry>06Jetta's Photo Gallery
I own a 95 Camry LEV6. The transmission refuses to shift out of second until the engine temperature gauge reaches the lowest line then everything's fine. It's not a big issue for me as I usually let my car warm up long enough so that when I reach the main road the problem is gone though in the winter months this process takes a little longer. Any thoughts?
Thanks.
95Camry>06Jetta is offline   Reply With Quote
Old 12-19-2010, 08:17 PM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Yes its normal, I usually let my car warm up to that first line, and the transmission will shift into third gear.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
The Following User Says Thank You to pmesfun For This Useful Post:
95Camry>06Jetta (12-19-2010)
Old 12-19-2010, 08:41 PM   #3 (permalink)
That is great to know. Thanks
Old 12-20-2010, 12:02 PM   #4 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
I've noticed if you drive to 70 km/h or more, it will shift regardless of temperature
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 12-20-2010, 01:30 PM   #5 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
Check the ATF level. Use a synthetic.
Delayed shifting when cold is normal. Just step on the gas some more and it will up-shift a little later when you're going a bit faster.
I would not say stuck in 1st is normal. How are you suppose to pull onto a highway?
deadrx7conv is offline   Reply With Quote
