Under the Valve Cover 95 Camry 5SFE [PICS] - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2010, 05:44 PM   #1 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
3rd Generation Under the Valve Cover 95 Camry 5SFE [PICS]
I have a leak around the #4 cylinder on passenger side and trying to rule out the "sources" one by one. Resealed the Valve Cover Gasket (VCG) again this past weekend. Reused the existing VCG as it's just one year old and looked good.
~175K miles on the car. I have owned from 133K. Neglected till 164K. Had only 3 oil changes till that time.I know I know I am an idiot But hey I hadn't discovered TN that time
Did 7 oil changes this year with Pennzoil HM 10W30+Purolator PureONE on ~2K Oil Change Intervals... ran my baby for 11K miles in 2010
Was prepared for worse when I popped open the VCG. How does it look?
BTW I am running Mobil 1 HM 10W-30 right now and leaking a lot.
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 12-20-2010, 06:29 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Ehhhh. Could be A LOT worse. That's pretty good considering the milage. My 5s-fe was a tad cleaner than that at 140k.
Here's what a REALLY clean one...
DIY valve cover gasket (pics)
'07 Honda Ruckus Big Bore
Old 12-20-2010, 06:35 PM   #3 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
I'll show you mine at 7k when I do my valve adjustment!
Chris Crash is offline   Reply With Quote
Old 12-20-2010, 06:53 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Looks OK.
No visible scoring or excessive wear on cam lobes or cam gears.
I would do the seafoam in the crankcase just before the next oil change to help clean it up some.
The Jedi Speeder at CarDomain
Old 12-20-2010, 08:33 PM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Yeah, that doesn't look bad at all, considering. It's got some staining or varnish or whatever, but nothing bad. But I'd be the first to say I'm no expert.
BMR is online now   Reply With Quote
Old 12-21-2010, 09:35 AM   #6 (permalink)
A camry n00b
peshwa's Avatar
Thanks guys for your replies. So there's no sludge per se, only varnish. But will varnish on these parts mean there is "more" in the block? Is it safe to run seafoam/B12 Chemtool on this motor? I wouldnt wish to damage this motor as its my only car right now
Old 12-22-2010, 12:16 AM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Yeah, thick varnish at places but not too bad given the history. Besides prior miles of neglect, varnish can also mean the oil is being cooked when owners are on a shorter 3-5K OCI.
How about AutoRX with dino oil? And then maybe go to Motorcraft Synthetic Blend (Walmart), Valvoline Durablend (Autozone recently ran a sale). If Fremont temps are like 50-60 deg F then 10W-30 should still work fine.
Auto-RX works best with a dino oil they list:
http://www.auto-rx.com/
Old 12-22-2010, 12:22 AM   #8 (permalink)
So what was the source of the leak?
Old 12-22-2010, 12:48 AM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
nothing terrible for the mileage if you ask me. I would change oil next time to dino, sea foam it and change oil again to dino (I know it's a 100mile / 1 day OCI, but it's HIGHLY recommended this way) and then use auto-rx (and then again OCI with dino for rinse phase ... it takes a while). whatever sea foam dislodged and you didn't drain will get liquified by auto-rx later. I think it's a safer way.
keep it on synthetic throughout the winter, it will do some more cleaning (did for my 5s-fe). you may want to change filter only half way through the Winter OCI (add 0.2qts of fresh oil after swapping filters).
I think you had an oil leak on cyl#4 from top of tube, meaning the grommet is bad or 30mm nut was loose. those bastards get loose sometimes. recently when re-doing timing job on 5s-fe like 2 months ago I found nuts below torque specs... and on formerly clean spark plug tube had liquid oil on walls inside ... I actually should re-torque them soon, they might be affecting my fuel trims again ...
does it leak from any other spot now? synthetic oils make leaks and seeping gaskets easier to spot because of their finer particles (and cleaning package they carry) when compared to dino oils (ask me how I know hehe)...
I assume mine looked similar to yours before sea foaming, almost same pattern of black streaks and spots here and there. pics in this thread, after sea foaming (and running on synthetic throughout Winter):
DIY Fuel rail & injectors removal - 4cyl i4 5s-fe gen4 camry - PICS !
I think this is how yours will look like later (note how most of black streaks under valve cover stayed and you can still see darker spots on spark plug tubes).
Old 12-22-2010, 01:39 AM   #10 (permalink)
Is that good? Or do I have some of the infamous camry sludge? Boy I hope it's not sludge...
Old 12-22-2010, 09:29 AM   #11 (permalink)
Camry Expert/MR2 JR Xpert
jtex2717's Avatar
Gameroom cash: $272115
View jtex2717's Photo Gallery
^Dick much???....
Finally Red MKII MR2 5s & Metallic Blue 96 Cam 1MZ
Watch out for the build thread!!!
IM BAAAAAACK!!!!!!!
jtex2717 is offline   Reply With Quote
Old 12-22-2010, 11:38 AM   #12 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
Originally Posted by Chris Crash View Post
too bad there arent any clear acrylic valve covers...
Old 12-22-2010, 04:33 PM   #13 (permalink)
Freakin Scooters
MAKE one.
Old 12-22-2010, 04:34 PM   #14 (permalink)
^Thought about it. No thanks. It'd be cool for a few thousand miles, then it gets dirty.
Old 12-23-2010, 11:20 AM   #15 (permalink)
A camry n00b
peshwa's Avatar
I am still hunting. I resealed the VCG and apparently the leak is still there. The #4 injectors have all kind of slimy dirt around them. But when I run my hands around the gasket I dont see a single drop or trace of oil. I am as confused as the democrats right now
Could there be significant blow by oil blowing out of the Fuel Injectors? What could be the other symptoms of such an occurrence?
Tags
5sfe, peshwa, valve cover gasket
