DIY: Check your valve clearances - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2010, 01:43 AM   #1 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Today I noticed on the warranty for my engine, it says
Valve adjustment is considered tune-up. Therefore it is CUSTOMERS RESPONSIBILITY.
So I went out to check the valves to see how off they were, and was pleasantly surprised. All my valves were within 2 thousandths of an inch of the lowest clearance, so I figure it'll be ok.
TOOLS NEEDED:
-30 mm socket
-19 mm socket
-Breaker bar
-Big screwdriver
-Feeler gauges
TIME REQUIRED:
-10 minutes
BIG RED DISCLAIMER: This is to be used a guide ONLY. Neither TN nor the author of this guide are to be held responsible due to any damages, injuries or death caused by the use of this guide.
That being said, let's get to work. Do this on a cold engine.
1) Remove the spark plug wires.
2) Remove the PCV valve and the hose going to the intake manifold.
3) Remove the PCV hose going to the intake tube.
4) Remove the four 30 mm nuts on the spark plug tubes.
5) Using a screwdriver, carefully pry up the valve cover. Avoid damaging the gasket.
6) You may need to finesse the cover out of there, but it can come out, trust me.
7) By turning the crankshaft, set the #1 piston to TDC. With the #1 cylinders valves loose and the #4 cylinders valves tight, it should look like this:
8) Take your feeler gauge and start shoving them between the buckets and the lifters. For the first time, check ONLY the intake valves of cylinders 1 and 2 and check ONLY the exhaust valves of cylinders 1 and 3. The clearances for the intake side should be 0.19mm-0.29mm (0.007in-0.011in) and for the exhaust side should be 0.28mm-0.38mm (0.011in-0.015in). If they are too loose (you can fit a feeler BIGGER than the highest clearance), then you shouldn't worry too much. It's when they are too tight and you can't fit ANY of the accepted clearance feelers in that you have a problem and might want to change your shims to smaller ones.
9) Once you have checked all the valves listed in step 8, rotate the crankshaft 360 degrees, making sure to align the notch to 0 again for TDC.
10) Now, check intake side of cylinders 3 and 4 and the exhaust side of cylinders 2 and 4. Same clearances.
11) Record any out of spec valves, they will be used for calculating the correct shims later if needed.
12) Put everything back together in reverse order, make sure to torque the valve cover nuts to 33 ft-lbs in multiple passes.
EDIT: Can't get the pics up right now. Will edit and post pictures tomorrow!
Chris Crash is offline   Reply With Quote
The Following User Says Thank You to Chris Crash For This Useful Post:
fenixus (12-22-2010)
Old 12-22-2010, 02:13 AM   #2 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 12-22-2010, 09:13 AM   #3 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
Why would you NEED pics? Have you never seen a valve cover or rocker arms? If you haven't you shouldn't be checking valve specs!!
Pvt-Public is offline   Reply With Quote
Old 12-22-2010, 09:24 AM   #4 (permalink)
Camry Expert/MR2 JR Xpert
jtex2717's Avatar
Gameroom cash: $272115
View jtex2717's Photo Gallery
Finally Red MKII MR2 5s & Metallic Blue 96 Cam 1MZ
Watch out for the build thread!!!
IM BAAAAAACK!!!!!!!
jtex2717 is offline   Reply With Quote
Old 12-22-2010, 10:11 AM   #5 (permalink)
pmx007PL's Avatar
View pmx007PL's Photo Gallery
3rd Generation Stickers in Camry...
There should be sticker somewhere inside engine room - sticker with valve clearances.
For V6 a bit smaller (intake 0,15-0,25 mm or 0,006-0,010" and exhaust 0,25-0,35 mm or 0,010-0,014").
pmx007PL is offline   Reply With Quote
The Following User Says Thank You to pmx007PL For This Useful Post:
Chris Crash (12-22-2010)
Old 12-22-2010, 05:05 PM   #6 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
BIG +1. And with that... sticky time.
'07 Honda Ruckus Big Bore
Old 12-22-2010, 05:58 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
nice, you did it man
I was too lazy to replace any shims haha even though at least 4 valves almost require new shims already ... but I will wait a while before I touch this, it's a PITA. the whole process of measuring is time consuming and exhausting a tad.
edit:
have you actually replaced at least one shim?
Old 12-22-2010, 11:44 PM   #8 (permalink)
View mr1114's Photo Gallery
How often should this be checked?
2006 Corolla S - sold
2003 Solara SLE - sold
2000 Corolla LE - sold
mr1114 is offline   Reply With Quote
Old 12-22-2010, 11:45 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
Haynes says every 60k miles, but in practice every 100k should be fine on most engines without other trouble (like sludging).
Old 12-22-2010, 11:54 PM   #10 (permalink)
Is it pretty common for the clearances to go out of spec? I've honestly never done it on any car I've owned. Didnt see it as critical and they always ran fine
Old 12-23-2010, 12:01 AM   #11 (permalink)
抵抗は無駄です
fenixus's Avatar
I'd say if you are into engine tune up and trying to keep the car at top notch then do it.
If you feel the car runs fine and engine runs quiet (and no other unexplained trouble present) then forget it.
It's hard to say for me why some engines need this service more than others, but yeah they eventually do fall out of spec (get tightened, not loosened).
The Following User Says Thank You to fenixus For This Useful Post:
mr1114 (12-23-2010)
Old 12-23-2010, 12:58 AM   #12 (permalink)
Nope I have not replaced a single shim. I'm not worried about it. Will re-check in 20 or 30k miles though, as it's as simple as pulling the VC off..
Old 12-23-2010, 01:06 AM   #13 (permalink)
抵抗は無駄です
fenixus's Avatar
so what were your numbers?
the most time i spent on bending over the engine bay and taking measurement and then notes... way more than 10 minutes for me. took me a good hour total and cause strong pain in my back the day after hehe.
Old 12-23-2010, 01:11 AM   #14 (permalink)
My engine's on the ground
Intakes were between .006 and .009
Exhaust between .009 and .012
So...good enough for me!
Old 12-23-2010, 09:53 AM   #15 (permalink)
抵抗は無駄です
fenixus's Avatar
hmmmm .... if norm (at cold) is 0.007-.011in for intakes and 0.011-0.015in for exhaust then some valves may be out of specs (too tight) ... just saying ...
man, I wish I could pull the engine (no tools, no garage makes it impossible) and do it off car ... it's such a pain to do on car...
Tags
adjustment, chris crash, clearance, shim, valve
