Oil level mystery... what is going on... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2010, 08:24 PM   #1 (permalink)
Never enough time...
View Mercfan's Photo Gallery
This is my dad's 2000 Toyota Camry LE (4cylinder). After draining old oil I've put 1 quart of new oil into it and decided to check exactly how many quarts it takes... the manual states that for 5S-FE engine it's .6Qts and for 1MZ-FE it's 1.3 Qts...
Since I've already added 1 full quart I thought it would already be too much - I was wrong! When I pulled the dip stick it was completely dry...
Confused, I've added another 1/2 quart and started the car just enough to get it off the ramps and shut off. Checked again after few minutes and it's still dry?!?!?
What am I doing wrong here?! What's the proper capacity for the 4 cylinder?!
THx,
James
Mercfan is offline   Reply With Quote
Old 12-22-2010, 08:30 PM   #2 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
THx,
James
I don't know where you are getting your specs from but they are wrong.
Minimum capacity after you drain the oil, and replace the filter is 5 quarts. The numbers you quoted "5S-FE engine it's .6Qts and for 1MZ-FE it's 1.3 Qts" are wrong, very wrong.
If you try driving much further, without adding the correct amount of oil you will ruin your engine, guaranteed.
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is offline   Reply With Quote
Old 12-22-2010, 08:39 PM   #3 (permalink)
I'm looking in the Toyota Camry 2000 Owner's Manual (in his glove box since new)... page 226
Old 12-22-2010, 08:51 PM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Can you scan, and post a pic of that page? My 96 5SFE has always taken 4.6qts every oil change.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 12-22-2010, 08:57 PM   #5 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
I know these camrys aren't big, but their not lawnmowers. There's a reason why they sell oil in 5 quart jugs.
4cyl is 4quarts of oil.
That 1.2 or whatever your saying is the differential capacity. Or the amount of oil that's in the filter. Either way if youve driven or run that engine with 2 or less quarts of oil for even a couple minutes shes dinked. Big time.
carsrus is offline   Reply With Quote
Old 12-22-2010, 09:00 PM   #6 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Jesus. That small amount of oil in the 4 cylinder engine is NOT going to make it happy. They HATE being low on oil. One quart is STARVING it. The correct capacity is 3.8 quarts. Just dump in 3 and a half jugs, then check the level. Add more as needed. Usually mine would take a full 4 quarts.
'07 Honda Ruckus Big Bore
Old 12-22-2010, 10:40 PM   #7 (permalink)
Pics
How do you post images?! Don't see a way to manage attachements... the only icon up there wants me to specify a URL for an image... well, the image is on my desktop....
Old 12-22-2010, 10:44 PM   #8 (permalink)
uibalnme's Avatar
How to post pictures
Old 12-22-2010, 10:46 PM   #9 (permalink)
Chemist at Chevron
Gameroom cash: $315485
View bdy0003's Photo Gallery
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 12-22-2010, 10:51 PM   #10 (permalink)
Pics included...
Thanks -
Here are the photos:
1) Back of the Owner's manual - which points you to page 226
2) Page 226 itself which proclaims to have all the details about the oil:
W T F?!
Old 12-22-2010, 11:00 PM   #11 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
That is the difference between the LOW and FULL level on the dipstick. That is not the capacity of the oil sump. Now look at the dipstick.
deadrx7conv is offline   Reply With Quote
Old 12-22-2010, 11:04 PM   #12 (permalink)
Well, I hope it's still ok - I started it with 1Qt in it for maybe 10 sec (if that)...
Old 12-22-2010, 11:05 PM   #13 (permalink)
Thanks -
W T F?!
Well it's right in front of you. If you look up two paragraphs you will see that it says the approximate quantity of oil needed to to fill between the low level and the full level on the dipstick is indicated below for reference. The quantity listed is how much oil needs to be added to bring the level from the "low" level to the "full" level. It has nothing, repeat, nothing whatsoever to do with the quantity of oil in the crankcase.
If you look at the back of the owners manual, you will find a section called Specifications. That's where you will find the the fluid capacities. And you will see that the Oil capacity is 5 quarts.
EDIT:
I just looked it up, Section 8, Specifications, and it's on page 252, upper left hand corner of the owners manual.
Old 12-22-2010, 11:28 PM   #14 (permalink)
View mr1114's Photo Gallery
If you're not hearing any new noises, you are probably ok.
2006 Corolla S - sold
2003 Solara SLE - sold
2000 Corolla LE - sold
mr1114 is offline   Reply With Quote
Old 12-23-2010, 12:37 AM   #15 (permalink)
Freakin Scooters
Oy vey...
What have we learned boys? Read twice. Out loud.
