Originally Posted by Jon101
Hello,
I have a 2000 Camry XLE 6-Cylender with 81K miles. The car runs fine in neutral but when I put it into drive and apply the brake pedal the car starts to have a vibration (vibration is not there when moving only in drive when stopped). We took it to the dealer and had the motor mounts replaced but that did not solve the problem. If anyone has any idea of what is wrong or can help please let me know.
Thanks,
Jon
Another suspect is the power brake booster - if the valve has a problem, or the diaphragm is leaking, it'll cause an air leak, with a rough idle, which will be most noticeable at idle. Checking things out with a scan gauge (looking at fuel trim and IAC opening, indicating an air leak) will help determine.
If the roughness is there without the service brakes applied (put in gear, test by applying parking brake and releasing service brake) the above is likely eliminated.
Another thing would be to turn on A/C - a bad mount/lazy IAC will 'sound off' with the added load of a compressor.
