Originally Posted by Safari Wagon
I think the OEM wagon springs are heavier duty than the sedan's / coupe's. You could install one of these to raise the height a bit - http://www.amazon.com/Mr-Gasket-1287.../dp/B000BWCFIM
Let me know what you end up doing. I may want to replace my shocks / springs at some point. (Even though I have not had any problems yet with four people, boating gear, and 200 pounds in trailer tongue weight pushing down past the rear bumper....)
It's weird, the suspension doesnt seem to sag much in the rear but bottoms out over many bumps when loaded... i know part of this is struts but after looking under the car while loaded......it's almot bottomed out.
does that mr. gasket thing fit inside the spring and act as a second stage or stack with the spring and simply make it ride higher?
last year i cut down a bunch of trees hauled them out to the cabin inside the wagon! i cut the logs the same lenght as the back area of the car and stacked them to the ceiling. i put a thin piece of plywood on the carpet and then covered it in a tarp. the car weighed about 900 pounds more than with just me and a full tank in it. i drove it over a scale before and after.
the interior is in amazing shape after all these years. you'd never know such red-neck behavior happened in this car. these cars age amazing!
