strange problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2010, 06:27 AM   #1 (permalink)
sexy, dirty, and slow...
93XLEcamry's Avatar
View 93XLEcamry's Photo Gallery
3rd Generation strange problem
first off, i would like to say merry xmas to all, an early one.......now on to the problem...
yesterday i started my car everything was fine, as i was driving down the road, the car decided to shut off by itself....luckily there wasnt any on coming traffic....but after it shuted off, i couldnt start the car back up.....i can hear it cranking up, but it just wont roll over....after many attempts the car started back up, and when in park, it stays on, but once i put it in drive, it'll go for ten feet then die.....and i have to restart the process again....and the car doesnt start that easily now too....
the check engine light didnt come on or anything...would using an obdII help diagonse the problem???
has anyone have this happen to them or are familiar with the problem here???
its a 93 xle v6...
93XLEcamry is offline   Reply With Quote
Old 12-23-2010, 09:02 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
an obdII scanner wont read right, youd need obdI.
sounds like it may be an ignition issue. weak spark under load.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 12-23-2010, 09:06 AM   #3 (permalink)
View getyourgunn's Photo Gallery
mine had those exact same symptoms when my distributor went bad but that is in a 4 cylinder 5sfe
getyourgunn is offline   Reply With Quote
Old 12-23-2010, 01:26 PM   #4 (permalink)
93XLEcamry's Avatar
So sparks and distrib Is there a way to see if this is the problem that's causing the problem?
Old 12-23-2010, 01:33 PM   #5 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
things to check,
For a more detailed description of each thing, Check out the following link:
DIY : HELP 92-96 5sfe CAMRY WONT START
Old 12-23-2010, 02:53 PM   #6 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
Get ready for another one of my completely unrelated stories.
I had someone come to me, their car was hard to start, and it wouldn't stay running. If you put it into drive it would die. They said that they had spent three days trying to figure it out. It had good spark, it had fuel pressure, the timing was correct, and the air filter was clean as new. I walked out took one look at it and knew the problem. Their wife had backed it into a snow bank and plugged the exhaust with snow. We both lolled.
But back on topic I would check the fuel pressure, and pull the cap off the distributer and check that the coil isn't cracked (v6 guys, the coil is under the cap same as the 3s/5s right?)
SexieWASD is offline   Reply With Quote
Old 12-23-2010, 04:22 PM   #7 (permalink)
View dudutzu's Photo Gallery
how much gas do you have left in the tank? bad/water in gas maybe?
dudutzu is offline   Reply With Quote
Old 12-24-2010, 03:28 AM   #8 (permalink)
93XLEcamry's Avatar
woow....first off thanks for the replies, but i do not know how to do or even check for all those things, i will be doing some research of how to do them....and DUDUTZU i have half a tank of gas left...and it was raining for the past few days here in sd...
Old 12-25-2010, 10:05 PM   #9 (permalink)
93XLEcamry's Avatar
does anyone know where the control valve is on the 3vzfe???....i know the gen 4 has theres right below the throttle b....
well i did a short quick cleaning of the tb, and did a sea foam...it starts, and seems like it is in working order for now...but still want to clean the control valve...read somewhere that that might be the problem...
