Need torque specs for 2000 Camry Fuel filter banjo bolt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2010, 11:49 AM   #1 (permalink)
Never enough time...
View Mercfan's Photo Gallery
What is the torque spec for the banjo bolt on top of the fuel filter on the 2000 Camry LE (4 cylinder)?!
Speedy response is appreciated (I'm in there now)...
Mercfan is offline   Reply With Quote
Old 12-23-2010, 12:14 PM   #2 (permalink)
Anybody?!
Old 12-23-2010, 12:21 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
You expect a response in 25 minutes in the middle of the day?
The Jedi Speeder at CarDomain
The Following User Says Thank You to MR2Jedi For This Useful Post:
LynchburgCSI (12-24-2010)
Old 12-23-2010, 12:25 PM   #4 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
Tight enough to not leak but not enough to strip the threads. What is with all the obsessing over torque specs? There are actually very few things that the exact torque makes any difference.
But to keep the annal retentive among us happy here ya go Torque: 29 N·m (300 kg·cm, 21 ft·lb)
Pvt-Public is offline   Reply With Quote
Old 12-23-2010, 02:15 PM   #5 (permalink)
Thanks very much - what is the obsession!? I've recently over-torqued a bolt on my Benz recently and caused myself all kinds of additional work... now I'm more cautious.
Old 12-24-2010, 07:41 AM   #6 (permalink)
Pvt-Public's Avatar
After you read enough of the ridiculous torque spec requests you will see what I mean. I mean do you really need an exact torque value for a battery terminal clamp? Or maybe a license plate bolt? If you find you are stripping or breaking a lot of bolts. Stop trying to prove how strong you are or instead of using a 1/2" ratchet use a 3/8" they are usually shorter so less torque. If you find your bolts and/or nuts loosening use a longer wrench.
