1995 camry issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2010, 06:41 PM   #1 (permalink)
View t-wrex's Photo Gallery
1995 camry issues
Here's my quandry- driving down the road, the engine stops. No warning, no fluids gushing out, no parts strewn down the road, it just quits. Cranks and cranks, but no start. Replaced the fuel pump on a hunch. Nothing. Took it to a shop, a guy that has worked on my cars before, and he discovers the timing belt has snapped. Puts on a new timing belt, and nothing. He suspects the distributor, so we try that- nothing. It will crank and run for a few seconds before dying. It will run and run if you spray fuel into the intake. So, new fuel pump, new timing belt, new dizzy, and nothing. It is getting spark, all the timing components are kosher, but still nothing. Fuel filter flows freely. 1995 toyota camry, 186,XXX, 4cyl. HELP!!!!
t-wrex is offline   Reply With Quote
Old 12-24-2010, 04:13 AM   #2 (permalink)
View dudutzu's Photo Gallery
Edit: nvmnd - your car doesnt have either of those
dudutzu is offline   Reply With Quote
Old 12-24-2010, 05:05 AM   #3 (permalink)
View tweak1029's Photo Gallery
Is it in time?
tweak1029 is offline   Reply With Quote
Old 12-24-2010, 06:25 AM   #4 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Flow is not pressure. What's the pressure?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 12-24-2010, 12:44 PM   #5 (permalink)
+1
also does your car have a MAF or equivalent that is responsible for fuel:air ratio?
Old 12-25-2010, 10:47 AM   #6 (permalink)
idk what the actual pressure is. i'll have him check taht as well. the crank angle sensor (think that's the right term) and the ignition module will be first on the list. been scouring the interweb, and there's as many opnions as there are viable solutions. been trying to find "what causes a timing belt to break" to no avail really. the belt was not beyond it's life. something happened to cause it to break. all the internals (as best as you can judge w/o tearing the engine down) are all kosher. *sigh* merry christmas. lol
Old 12-25-2010, 09:40 PM   #7 (permalink)
It's fuel. You've got spark, compression, timing. Either you've got no pressure or you've got no injectors.
Old 12-26-2010, 08:45 AM   #8 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
you sure the guy put your timing belt or distributor on correctly? If anything is 180 degrees out it will not start, but it will still spark
EDIT:
I just re-read your post.. Its running for a second and then dies.
You need to have him run an in-line fuel pressure test and see what kind of pressure your getting past the fuel filter first.
Old 12-26-2010, 06:13 PM   #9 (permalink)
Did your car run smooth before this? Does it run smooth now? Does it stay running when you give it gas?
Assuming the new fuel pump works, and all that was changed dealt with timing, I would look closer at the timing. I have a Maxima that was out of time. It would run for a couple seconds before dying if I didn't open the throttle. That was ignition timing but I suppose it would be similar if the valve timing was out.
EDIT: Yeah, checking the fuel pressure wouldn't be a bad idea. Something could have gone wrong there.
Old 12-27-2010, 09:59 AM   #10 (permalink)
def will have him check the fuel pressure. it ran like a champ until this happened. i panicked and threw a new fuel pump in it, but that changed nothing. i am pondering putting the old fuel pump back in it! lol it starts and runs for sec by itself (until the prime runs out), and will run smooth w/ fuel sprayed into the intake. if you give it throttle, it dies immediately. i will have him double/triple/quadruple check the timing and the fuel pressure. could this be an ignition module... or would that keep it from starting at all? is there a sensor or something that tells the pump to continue pumping once the engine is started? it just baffles me that it will run for a second, then croak.
Old 12-29-2010, 09:04 AM   #11 (permalink)
sooooo... i took the original fuel pump to the mechanic, and had him check fp, double check timing (which was as close to factory fresh as you can get), and some other odds and ends.... turns out, much to my amazement, that the fuel pump was wired exactly backwards. yup. followed the instructions that came with the aftermarket pump, to the letter, and as it turns out, they're wrong. but only by color identification, so no big deal. oh well, at least IT'S RUNNING!!!!!!! WOOOHOOOOOOOO!!!!!! thanks for all the input- you guys are the bestest!
