Vibration in '01 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2010, 02:20 PM   #1 (permalink)
View divine's Photo Gallery
RE: Vibration on '01 Camry LE Sedan
As of the last few days, I've noticed that when my Camry idles that the steering wheel as well as the door (if I have it ajar) vibrate; seems like the idle is a little rough.
Any quick solutions to this problem?
Thank you.
Larry
divine is offline   Reply With Quote
Old 12-25-2010, 02:37 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
No Check Engine light?
Its normal then. 4cyl engines arent to smooth at idle.
carsrus is offline   Reply With Quote
Old 12-25-2010, 03:08 PM   #3 (permalink)
Gameroom cash: $177655
View deadrx7conv's Photo Gallery
If its never done it before, time for a tune up and cleaning.
deadrx7conv is offline   Reply With Quote
Old 12-25-2010, 05:12 PM   #4 (permalink)
Gameroom cash: $160515
View mdatrdcam's Photo Gallery
maybe your motor mounts are wearing out.
just a thought
FULLY LOADED 01 V6 5-SPEED-INJEN INTAKE-TRD QUICKSHIFTER-FULL TRD SUSPENSION-TRD STRUT TOWER BAR
mdatrdcam is offline   Reply With Quote
Old 12-25-2010, 06:48 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Also try shifting from P or N into D or R. See if there is a bigger jolt than before. If so it's likely the mounts. The "dog bone" linking the engine to the right strut tower is easy to check. See if the rubber is cracked.
Bad plugs and wires can do this too. If it's not the mounts, then a tune up with new NGK Iridium-IX plugs and NGK spark plug wires may help. Check resistance on the coil packs too.
Old 12-25-2010, 08:57 PM   #6 (permalink)
Gameroom cash: $125050
View redtigerrocks's Photo Gallery
Definitely check plug/wires first- I had the same problem with my 94 V6 and it turned out the plugs had to be change... Another sign is a decrease in gas mileage if your actually recording/paying attention to it.
redtigerrocks is offline   Reply With Quote
