'94 Toyota Camry radiator replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2010, 01:31 PM   #1 (permalink)
View zakkie's Photo Gallery
Someone backed into our camry and in so doing broke the radiator along with some other damage. It is going to have to be replaced but I noticed that there was a wire that got cut at the bottom. What is this and where can I find replacement. Also, the fan bodies corners where attach to the radiators are all broken off. Does anyone have any websites that might sell the fans cheap to replace.
Thanks for any help
zakkie is offline   Reply With Quote
Old 12-27-2010, 02:03 PM   #2 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
To save money/ time what I have done with plastic & similar type repairs is:
1. Align the broken pieces, use epoxy to mend/repair the break
2. Reinforce the repair using galvanized coated 16-18ga sheet metal and pop rivets (this part will depend on the room you have available for the rivet stems).
Over the years I have done this repair on quite few items, ranging from radiator supports to below bumper air dams. As far as I know they are still in service/use.
Good luck
Sturdavj is offline   Reply With Quote
Old 12-27-2010, 03:25 PM   #3 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $324600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
Is it a 4cyl or 6cyl?
4cyl OEM radiator for TN members is $130.85(MSRP is $186.93) part #16410-YZZAA.
6CYL OEM radiator for TN member is $162.94 (MSRP is $232.77) part# 16410-YZZAB.
Thanks for any help
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 12-27-2010, 07:21 PM   #4 (permalink)
It is a 4 cyclinder. Is the wire part of the engine coolant sensor?
Old 12-27-2010, 09:02 PM   #5 (permalink)
I don't know without more information. Can you post a picture?
678-854-9601
Old 12-28-2010, 06:32 AM   #6 (permalink)
No way to get picture. There is a white piece on bottom of radiator with nothing connected to it and the wire looks like it is going to one of the fans (the one on the driver side of car). It appears that when it got pushed back it snapped the wire off.
Old 12-28-2010, 06:56 AM   #7 (permalink)
The 4CYL has a tempature Detect switch on the bottom of the radiator towards the drivers side. From your description, it sounds like the wire that is connected to it is either unpluged or as you say, been pulled away. If the white piece at the bottom of the radiator has an electrical connector, I am guessing that is what the wire goes too. I don't have one of those temp switches in stock to see what color the head is. It could be white or a redish brown.
678-854-9601
