False Tailight burnout Light! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2010, 10:03 PM   #1 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
This just started happening on my 93 Camry. My Dashboard tailight burnout warning light, started lighting up everytime I hit the brakes. Yet multiple checks of all of my brake lights show they are all functioning fully. All side lights, High mounted rear window, spoiler, perfect. Not an emergency, but really annoying to have a dash warning light, light up every time you hit the brake pedal. Any ideas on what this could be?
Silent Runner is offline   Reply With Quote
Old 12-27-2010, 10:06 PM   #2 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
I would check all bulb connectors for loose connections or corrosion.
Make sure the primary and secondary bulb lights up. ie hitting the brakes and not hitting the brakes
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 12-27-2010, 10:59 PM   #3 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I have that too. I cannot figure it out for anything!
RichieRichJP is offline   Reply With Quote
Old 12-28-2010, 09:22 AM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Its either a wiring problem to the harness connectors, or your Brake light out warning light module is going bad. Have a helper hold the brake, or jam a piece of wood to hold the brake in place and wiggle the wiring to the taillights. If thats all good, then Pull back the drivers side trunk carpeting and pull the Module out and pull the cover off and inspect it for burns.
Old 12-28-2010, 09:39 AM   #5 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
The warning bulb isn't only for broken bulbs, its also a warning that bulbs are ABOUT to break.. so I'd keep checking, see if some bulbs are dimmer than usual. The filament of the bulb may be corroding and needs to be replaced soon, throwing off the resistance and hence the warning light.
iovaykind is offline   Reply With Quote
Old 12-28-2010, 10:00 AM   #6 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Exactly. The resistance of the filament goes up right before a bulb is about to blow. And corrosion on the metal tabs of the bulb/sockets can also lead to the light coming on. The light works on RESISTANCE. Nothing else.
Question for the OP... does the light go off when the pedal is released? If so, that's not supposed to happen.
'07 Honda Ruckus Big Bore
Old 12-28-2010, 12:18 PM   #7 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
Ok this is what happen to me, I have the blub in my hand it's a #1157 GE manufactured in hungry. Filaments are good
My dash indicator was signaling intermittingly lamp out, I would go back & thump the right TL, light would come until the next bump came along. After getting tired of this I pulled the blub.
This what I found, the two lead contact points on the base of blub were pounded flat, even maybe a little indented.. I have seen this before, back in the day when blubs were built to last a little longer.
I suspected poor contact in the socket, so I replaced the blub and the problem went away. Now the same problem is beginning with the left side TL, it's only a matter of time until I get tired of whacking it…. and spend the $ for a new blub.
Being cheap is a curse, I would not wish on my enemies
Sturdavj is offline   Reply With Quote
Old 12-28-2010, 01:28 PM   #8 (permalink)
I've swapped out all of my bulbs already and changed the harnesses out, I still have it.
Are you sure that indicator light doesn't have anything to do with the headlights too?
Now I do have a problem with my Scepter headlights for sure.
Old 12-28-2010, 01:35 PM   #9 (permalink)
The light indicator is for the rear taillights only.. doesn't do anything for the headlights
Old 12-28-2010, 01:36 PM   #10 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Check the lamp failure box. This might be a dumb question...but are you using the right lights?
Chris Crash is offline   Reply With Quote
Old 12-28-2010, 05:36 PM   #11 (permalink)
Freakin Scooters
Agreed.
+1
Old 12-28-2010, 05:45 PM   #12 (permalink)
Domesticon Prime
Does it go off when...
Interesting, it does indeed go off when the pedal is released. In responce to several other inquiries, I have checked all the filiments in all the bulbs and the condition of all sockets and bulb contacts.The bulbs all seem to have the same brilliance, and the connections are corrossion and damage free. I was slightly aware of the test circuits use of resistance to active the light, but it was clearly pointed out to me when I tried replacing all of my tailight bulbs with LED replacements some time ago. (They were also to directional for the mounting system and to dim). It sounds as though I'm going to have to look at this "failure module", mounted in the trunk. I'm also going to try a little dialectric grease in all of the bulb sockets. Thanks for the ideas!
Old 12-28-2010, 05:47 PM   #13 (permalink)
Of course I'm using the right lights lol
Dude, you're going to have to tell me where the lamp failure box is on the Camry. I do all my work on the MR2 lol
Old 12-28-2010, 06:59 PM   #14 (permalink)
Gameroom cash: $155150
View wilsonman02's Photo Gallery
Yeah i have a similar and weird problem with this as well. My indicator is on. All the rear lights are on, but when i hit the brakes to the two brake lights closest to the license plate go out, and the far side ones and top mount go on. Just think its weird they work until i hit the brakes, and BTW they both went out at the same time.
wilsonman02 is offline   Reply With Quote
Old 12-28-2010, 08:27 PM   #15 (permalink)
Open the trunk. Pull the carpet off the left hand side near the front of the trunk (if you're standing behind the trunk, it's towards the front of the CAR) and there should be a little blue or black box.
