You can do a search, there are several threads on this forum regarding the P0401 code.
You could have blocked EGR ports, even though applying vacuum caused the engine to stumble.
There is a port that goes to the bottom of the modulator via a hose. This port could be blocked or the hose could be leaking. This hose applies back pressure to the modulator which allows it to operate.
Try removing the EGR valve and clean out the ports, if blocked.
If you have a service manual, it explains how to test the EGR system.
