DEI 530t an Python 990 Relay Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2010, 02:44 AM   #1 (permalink)
View numbr1westsida's Photo Gallery
4th Generation DEI 530t an Python 990 Relay Install
I recently decided to add some upgrades to my existing python 990. following a few guides on here, i was able to install my trunk pop with relay and everything work great. barely even notice it. (pictures soon to follow of how to do it.) Now i can pop the trunk with remote or by pressing the trunk button now also located in the glove box for passenger convenience.
I also installed 2- DEI 530t's to control all 4 windows automatically. i wired it up successfully connecting the wires as instructed. now all the windows will "one-touch" roll down/up from the driver door, as well as auto roll up when the car turns off (connecting the Ground when Armed wire from the two 530's to the Ground when armed wire from the 990).
Ild like to connect the two 530t's to the 990 brain so i can control them through an AUX channel (5 is the only open one in my system). I have a relay exactly identical to the DEI 610t (as seen here
Amazon Amazon
). Ive tried various configurations but cant seem to trigger the channel to roll the windows down.
Any help is greatly appreciated. Ive spent countless hours on google looking into it, and it doesnt seem many people connect relays for AUX channels and instead are connecting them to the Unlock trigger (i live in oakland, and with the amount of rain we get, that would not be ideal for a leather car)
I have a 2000 Camry Le 4cyl.
Python 990
2x- DEI 530t
DEI 522t
numbr1westsida is offline   Reply With Quote
Old 12-29-2010, 07:44 AM   #2 (permalink)
View hzt30's Photo Gallery
Have you tried the12volt.com. Lots of good info on security systems, remote starters, alarms, etc.
http://www.the12volt.com/
hzt30 is offline   Reply With Quote
Old 12-29-2010, 08:06 AM   #3 (permalink)
ive browsed through there for quite some time. none used a negative pulse from a command module to switch a relay. most used door unlock trigger.
Old 12-29-2010, 12:37 PM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
That's a dang nice security setup. I'm jealous. I'd advise that you register over at the12volt.com and post in their forums for something like this. Also... be sure your aux channel is set for a constant ground. I think that's what you'd need instead of a pulse signal.
'07 Honda Ruckus Big Bore
