can stock highlight wires/circuit support fog lights? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2010, 01:15 PM   #1 (permalink)
akhoundog's Avatar
View akhoundog's Photo Gallery
i just bough some hella ff75 lights and was wondering if the factory wiring harness and stuff can handle the amperage? I tried searching but the force is weak with me.
akhoundog is offline   Reply With Quote
Old 12-29-2010, 01:25 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
The Following 2 Users Say Thank You to Mister_Perkins For This Useful Post:
ajkalian (12-29-2010), woodye85741 (12-30-2010)
Old 12-29-2010, 01:33 PM   #3 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Easy answer...No. You'll have to use a 12V 30 amp relay to run the fog lights. You can tap into the stock headlight or corner light wiring to use it as a trigger to activate the relay, and thus, activate the fog lights.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
The Following 2 Users Say Thank You to uibalnme For This Useful Post:
Cryoman (12-30-2010), woodye85741 (12-30-2010)
Old 12-29-2010, 11:45 PM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
^ Agreed.
'07 Honda Ruckus Big Bore
Old 12-30-2010, 02:13 AM   #5 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
uibalnme drew a very good wiring diagram and is very similar to mine. The different is that I tapped into the heated seat 20A at the fuse box to trigger the relay instead of the low beams. So when my ignition key is on, the fogs are on too; like DRLs. But I can still disable it with the switch. The advantage to this is the fogs will stay on when high beam is enable.
What ever you choose, do the relay set up. I seen others run a straight wire from the battery to a switch on the dash back to two oversized fog lamps with no fuse. Can you say fire?
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is online now   Reply With Quote
Old 12-30-2010, 10:17 AM   #6 (permalink)
uibalnme's Avatar
Originally Posted by Yuko View Post
uibalnme drew a very good wiring diagram and is very similar to mine. The different is that I tapped into the heated seat 20A at the fuse box to trigger the relay instead of the low beams. So went my ignition key is on, the fogs are on also; like DRLs. But I can still disable it with the switch. The advantage to this is the fogs will stay on when high beam is enable.
What ever you choose, do the relay set up. I seen others run a straight wire from the battery a switch on the dash back to two oversized fog lamps with no fuse. Can you say fire?
Credit where credit is due. That's not my diagram. I found it on google. Anyway, I wired my fogs into the corner lights(no switch). The only thing about that is the fogs flash along with the corner lights when I turn the alarm on or off. That may not be a bad thing though.
Old 12-30-2010, 10:46 AM   #7 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
The trick is to wire them so that when you key out, the lights go out.
In my 1986 Corolla DLX; I used a 12vdc power source for the relay, however I was not able to find an easily accessible 12vdc power source for my dash switch. The source I used is powered up all the time… hence should I forget to switch them off the battery goes dead and out comes the jumpers, a royal PIA
Sturdavj is offline   Reply With Quote
Old 12-30-2010, 11:02 PM   #8 (permalink)
akhoundog's Avatar
ah ok, THANKS!
the hella kit i bought comes with a relay so i should be able to use the headlight wires to activate the relay.
this helps a bunch, thank you. I've never installed light before but am semi-familiar with dc wire from r/c stuff.
Old 12-30-2010, 11:34 PM   #9 (permalink)
uibalnme's Avatar
It's really easy to wire everything up. Just make sure you use weather proof connectors, and use split tubing to protect the wires. The hardest, and most time consuming part is routing the wires so everything looks neat and clean.
Old 12-31-2010, 08:42 AM   #10 (permalink)
As a point of interest;
My fog lights are yellow/amber, there can be times when there is a great deal of fog in my drive area. (Oregon Cascades)
I turn off my head lights off, and drive using just the fog lights, they are 55 watt so it is legal. This helps to eliminate the white back glare, that can occur with dense fog.
