99 Camry Vibrates Violently at 55 mph - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2010, 03:33 PM   #1 (permalink)
View sabbates's Photo Gallery
4th Generation 99 Camry Vibrates Violently at 55 mph
Help!
My 99 Camry vibrates violently at 55 mph and above!
Below that speed, it's not so bad. The vibration stays when I shift into neutral at 55 mph, which makes me think it's not an engine mount, as the RPMs drop. The vibration stays until the speed drops.
I replaced the passenger side axle because the CV boot was torn- didn't help. The driver side axle boots look good.
I rotated the tires using a spare, thinking one tire was no longer balanced, or maybe a rim was dinged - didn't help.
Any ideas would be much appreciated!
-Sabbates
sabbates is offline   Reply With Quote
Old 12-29-2010, 03:36 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Jack the front of your car in the air grab the tire at 12 and 6 o clock and pull and push the tire. Also at 3 and 9 o clock and repeat. If you feel any excessive movement or play, have a helper wiggle the tire while you inspect where the play is coming from. If you don't notice any play, take it to a reputable tire shop and have them check your tires / rims out for Bends or broken belts
Old 12-29-2010, 03:40 PM   #3 (permalink)
Mister Perkins-
Thanks a lot. I'll give it a try!
-Sabbates
Old 12-29-2010, 03:49 PM   #4 (permalink)
Also, make sure your Emergency Brake is engaged before jacking the front end up . hehe
Another thing you can test too is to stick a large pry bar underneath the tire and put pressure on the bottom of the tire to see if the ball joints are going bad. You should have camber wear if your tires are going bad though
Old 12-29-2010, 03:58 PM   #5 (permalink)
Mister Perkins-
Sorry, I didn't quite understand that last thing you recommended.
Am I supposed to do this test with the front jacked up? If so, how do I pry so pressure is placed on bottom of tire?
Thanks,
-Sabbates
Old 12-29-2010, 04:01 PM   #6 (permalink)
While the front tires are off the ground, you place a pry bar under the tire and pull handle closest to you up, putting pressure against the underside of the tire. You can also place a block of wood under the handle and push on the bottom side of the tire like a fulcrum too:
Kind of like the picture above, but you place the prybar on the bottom of the tire rather than the center
Old 12-29-2010, 04:09 PM   #7 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Either that or you need new shocks. Maybe check out your shocks if they're blown or a simple alignment might help if perkin's advice doesn't help.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 12-30-2010, 04:51 PM   #8 (permalink)
O.K., I'm an idiot.
It turns out the ply on the back rear tire was coming undone.
I never even looked back there because the vibration sound always seemed like it was coming from the front.
I replaced the tire, and the problem is solved.
Thanks for everyone's help!
-Sabbates
