camry gauge fuse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2010, 06:38 PM   #1 (permalink)
View Lee250's Photo Gallery
99 camry gauge fuse
I recently swapped motors in my 99 camry, 4 cylinder, cause the old one siezed. Everything works good now except that after driving about 3 or 4 miles the gauge fuse pops. Which shuts off the charging system and gauges and a bunch of other stuff. If I change the gauge fuse as soon as the car is put in drive again the fuse pops again. The car was sitting for a while and I know there was a mouse in there but this is the only problem and I don't see any evidence that the mouse was chewing on wires. Like I said after a cold start driving 3 or 4 miles then it pops. But once it pops it pops ever time its put in drive after that. It only seems to pop when put in drive. any thoughts? I looked up the wiring and didn't see anything related to that fuse when the car is in drive.
1986 Camry 2.0 Not going to let it die currently 228,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline   Reply With Quote
Old 12-22-2010, 06:47 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
What car did the donor engine come from?
'07 Honda Ruckus Big Bore
Old 12-22-2010, 07:36 PM   #3 (permalink)
97. same motor and all the wires were the same except for the oxygen sensor.
1999 Camry 2.2
Old 12-23-2010, 07:12 PM   #4 (permalink)
anybody have any ideas? what is activated in drive that is not in any other gear?
1999 Camry 2.2
Old 12-30-2010, 12:59 AM   #5 (permalink)
4th Generation camry gauge fuse
Ok update, still have not found the cause for blowing the gauge fuse. It still does it only when put into drive and will now do it even without being driven and with the engine off. Anybody know what circuits are turned on only when put in drive? Also anybody know where to get free wiring diagrams? I have the haynes manual but its not that great.
1999 Camry 2.2
Old 12-30-2010, 01:15 AM   #6 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Well there's obviously the lights... try taking the bulbs out and see what happens.
I don't really know what else goes in for automatics when you shift into D other than it goes forward...
Chris Crash is online now   Reply With Quote
Old 12-30-2010, 01:26 AM   #7 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
First thing:
Do you have the correct fuses?
Second: It's probably wiring problems. Maybe your wires are too old and can't maintain a steady wattage when you turn on your car. Check if any wires and conduits need replacing.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 12-31-2010, 02:50 PM   #8 (permalink)
yes i got the right fuses. no the wiring all looks good. another? is there a seperate computer for the trans or is it built into the ecm? I found a really good wiring diagram and tells what all the fuses do and I've narrowed it down to the computer for the trans. or a wire in that circuit.
1999 Camry 2.2
Old 12-31-2010, 03:09 PM   #9 (permalink)
Link Removed -Mods
Best wiring diagrams and tells what all the fuses do and connector locations and ground points. for 99 don't know what other years it will work for.
1999 Camry 2.2
Last edited by LynchburgCSI; 01-02-2011 at 03:32 PM. Reason: FSM Link Removed, Infraction Sent.
Old 12-31-2010, 04:19 PM   #10 (permalink)
View gyjoe's Photo Gallery
When I had the fuse for the gauges blowing on my '98 it was when shifting into reverse. The cause was the wiring harness for the lights on the trunk lid, which flex each time the trunk is open and closed. The wires eventually break near the support arm for the trunk, and make contact with each other, blowing the fuse. In my case, this happened when shifting into reverse, but perhaps the motion of shifting into drive in your case lights up the reverse lights just enough to blow the fuse. You could try a new fuse and then shift only into reverse and back to see if the fuse blows; if so, you will know what's causing it. Just thought it might be worth a shot.
gyjoe is offline   Reply With Quote
Old 01-02-2011, 02:41 AM   #11 (permalink)
Thanks but it wont blow even if sitting in reverse for a while. But as soon as it is shifted into drive it blows, like the little D on the gauges dosen't even have time to light up it happens so fast.
1999 Camry 2.2
Old 12-24-2011, 05:53 PM   #12 (permalink)
Gameroom cash: $106500
View Hellpowder's Photo Gallery
Did anyone ever find a reason for the fuse blowing? it seems im having the same problem
Hellpowder is offline   Reply With Quote
Old 12-24-2011, 06:40 PM   #13 (permalink)
It ended up being a wire against the EGR tube and melted so it was shorting out on the tube. But I did an engine swap and just routed the wire wrong. If your car is all stock and factory than you shouldn't have a melted wire anywhere.
1999 Camry 2.2
