I Need Help PLEASE!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-30-2010, 11:26 AM   #1 (permalink)
Jonate's Avatar
Gameroom cash: $257150
View Jonate's Photo Gallery
http://i1093.photobucket.com/albums/...1/DSC00401.jpg
http://i1093.photobucket.com/albums/...1/DSC00403.jpg
http://i1093.photobucket.com/albums/...1/DSC00402.jpg
I have stretched the fenders, and stacked the spacers (adding up to be a little less than an inch), but I have found out that local autoshop spacers are not the way to go. Since the weight of the wheel lies on the bolts, I run a great risk of breaking the bolts, and the car vibrates violently due to the spacers. I need to order Hubcentric Spacers that are custom made because there are none out there that are the exact fitting that I need. Any information about how Hubcentric Spacers work, any negatives and positives about them will be great! The wheel bolts are 2.5" (Are they too long, just right or will I run into more problems)
P.S. Would Hubcentric Spacers solve the vibration problem?
Jonate is offline   Reply With Quote
Old 12-30-2010, 12:06 PM   #2 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Roll the fender MORE.
Get lower tires.
Get thinner tires and stretch them.
Chris Crash is online now   Reply With Quote
Old 12-30-2010, 01:59 PM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
9.5" wide in the rear, eh? What's the offset on those? I'd assume you're going to need to run a HUGE set of spacers in the rear. Also... NEVER NEVER NEVER stack spacers on the same wheel. One ONE per wheel. Just making sure since your original post wasn't clear.
'07 Honda Ruckus Big Bore
Old 12-30-2010, 03:17 PM   #4 (permalink)
New struts would help. Lower the front, the rear looks fine how it is.
Old 12-30-2010, 03:27 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
I'll never understand staggered (or wider rear) wheels on a FRONT wheel drive car.
WOW.
Zembonez is offline   Reply With Quote
The Following User Says Thank You to Zembonez For This Useful Post:
CamryWilly (12-30-2010)
Old 12-30-2010, 04:07 PM   #6 (permalink)
Jonate's Avatar
WOW.
Well it is a big mix up. Originally I wanted all 9.5 on the entire car (i had no idea 9.5 was that deep) and they said that they would fit. Then they called back and told me that they had ordered them staggard. I said oh well whats done is done I will put them staggard. But now the rear dont fit. Its a big mess and they say they cannot refund my money.
(My intention was to get all four wheels the same size)
Old 12-30-2010, 04:09 PM   #7 (permalink)
Jonate's Avatar
Uh Oh... why not? I had to use two 5/16 spacers on each side.
I have only driven my car 10 miles, basically drove it from the shop to my house.
I hope nothing messes up
Old 12-30-2010, 04:37 PM   #8 (permalink)
Gameroom cash: $192100
View SexieWASD's Photo Gallery
Did it hit the tube on the strut, or the spring seat? if it hit on the spring seat then a set of coilovers should fix the problem, and you would have a set of sweet struts.
SexieWASD is offline   Reply With Quote
Old 12-30-2010, 04:40 PM   #9 (permalink)
Jonate's Avatar
It hits the tube because they are wide. I put spacers, but now they hit the fender when it goes over a bump.
Old 12-30-2010, 04:47 PM   #10 (permalink)
Freakin Scooters
That's a MAJOR safety issue. Take them off. NOW. Seriously. That's wayyyyy too high of a chance that something will break.
Old 12-30-2010, 05:07 PM   #11 (permalink)
Jonate's Avatar
I have a truck that has two on each side and I have never had a problem with that (15 years). But I will take your advice. (Where can I get big spacers?)
Old 12-30-2010, 06:44 PM   #12 (permalink)
Freakin Scooters
Old 01-02-2011, 11:52 PM   #13 (permalink)
mr.nitro's Avatar
View mr.nitro's Photo Gallery
try putting the wider ones up front and see what happens. might work. worth a shot.
1997 camry
mr.nitro is offline   Reply With Quote
Old 01-03-2011, 12:17 AM   #14 (permalink)
Aren't spacers just metal discs essentially? So with two stacked on top of each other, then squished between a hub and wheel, I fail to see any safety issues. Where/what could break?
Old 01-03-2011, 02:06 AM   #15 (permalink)
View mspringer's Photo Gallery
Braking and accelleration create a lot of stress on the hubs, and a lot of heating and cooling take place. I would think expansion and contraction may be an issue to the wheels loosening over time. Not to mention that cast (cheap) spacers can crack, and you definately may have an issue with not having a long enough wheel stud - there are probably only a few threads left holding the nut. Fortunately, there are a lot of sources for billet spacers that bolt to the hub and have new studs. (At least for trucks and American cars, not sure about a Toyota bolt pattern.)
Also, the tires on the rear wheels look really bizarre in the pic - too narrow and tall. It looks like the rim could use a much wider tire with a shorter sidewall, but that likely won't fix your problem. Narrower rims would...
Personally, I would sell the wheels and buy something that fits.
mspringer is offline   Reply With Quote
The Following User Says Thank You to mspringer For This Useful Post:
Chris Crash (01-03-2011)
