brake light on 1998 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2010, 12:43 AM   #1 (permalink)
View twocamrys's Photo Gallery
The red brake light on my dash comes on periodically. The light usually only illuminates when the brakes are applied. It happens more frequently when it is really cold outside. I checked the brake fluid and it appears fine. Does anyone have any suggestions on what could be causing this? Since the light doesn't come on every time the car is driven, I am stumped.
twocamrys is offline   Reply With Quote
Old 12-31-2010, 12:50 AM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Low brakes pads is a possibility.
'07 Honda Ruckus Big Bore
Old 12-31-2010, 01:02 AM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
check fluid level, sometimes when brake fluid is low in the reservoir it may cause the light to come up occasionally. however reason for low brake fluid (besides leaks) would point to very low life left on all pads (as mentioned above).
Old 12-31-2010, 01:24 PM   #4 (permalink)
Gameroom cash: $303755
"I checked the brake fluid and it appears fine."
Did you actually remove the cap on the master cylinder reservoir or did you just look through the translucent side? Many times old and dirty fluid will stain the sides of the reservoir making it look full when it is actually low.
Mike
Old 12-31-2010, 01:32 PM   #5 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
I agree. This usually happens when the fluid level is borderline low. Adding a bit of fresh fluid may well solve the problem.
Zembonez is offline   Reply With Quote
Old 12-31-2010, 01:56 PM   #6 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
I had a similar problem on my 86’ Corolla. I TS it and found the switch on the E-brake needed to be adjusted. I did so and problem has not returned.
Sturdavj is offline   Reply With Quote
Old 12-31-2010, 04:24 PM   #7 (permalink)
View gyjoe's Photo Gallery
I've experienced the same thing in several well maintained vehicles in extremely cold weather. It has always gone away once the cold snap is over.
gyjoe is offline   Reply With Quote
