Heat shield issues... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2010, 11:50 PM   #1 (permalink)
Custom fab's my specialty
Leviathan66610's Avatar
View Leviathan66610's Photo Gallery
While removing the lower heat shield to upgrade my rear drum brakes to disc I ran into a problem. Every single bolt's head snapped right off as soon as I spun em due to so much rust. I'm worried about not having a heat shield there now the only way to fix this would be to have the holes drilled and re-threaded but that would be too expensive, I'm just wondering if anyone has had the same problem or would it just be fine like it is?
92 Camry LE 270,000+ Miles (It will never stop!)
http://www.cardomain.com/ride/3825743
"Everywhere I go, I'm known as the Camry expert."
Leviathan66610 is offline   Reply With Quote
Old 01-01-2011, 03:27 AM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
check Harbor Freight Tools stores/website for their pricing and you will be surprised how cheap you can get what you need to fix it yourself.
