It'll be tough diagnosing without a trouble code to guide you. You're correct about cruise light flashing if there is a stored code, but I'd check anyway. Use jumper wire on Tc and E1 of data link connector (DS under dash) and watch for flash of cruise light. If no DTC then it's old fashioned circuit checks of the components for which you'll need a manual. My FSM says no cruise with no DTC indicates cruise ECU power source or cruise ECU, but factory manuals are not known for thinking outside the box. I'd check the cruise switch, stop light cancel (which may be shorted) and power to the actuator. It may help if you can replace the cruise ECU with known good one to see if it is the ECU.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
