harmonic balancer TDC? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2011, 05:07 PM   #1 (permalink)
View velorossa's Photo Gallery
With the harmonic balancer on the crankshaft, how can you tell when you are at TDC? I see there is a notch on the pulley, and timing marks on the motor (15,10,5,0 etc). Does that notch need to line up with 0 for tdc? This is for a 3vzfe motor. I know how to find tdc with the balancer off but I want to confirm it's still at tdc with everything back together.
velorossa is offline   Reply With Quote
Old 01-02-2011, 05:24 PM   #2 (permalink)
View camry6's Photo Gallery
The 0 on the timing mark indicator is TDC for the crank. This mark, along with the marks on the camshaft against the marks on the rear camshaft shroud should all line up perfectly when the belt is installed properly.
1993 Toyota Camry V6 LE (200 HP, 195 ft/lbs tweaked) , 430,000 km's.
2002 Lexus GS 430 V8 VVT-i (300 HP, 325 ft/lbs) Luxury with Mark Levinson , 156,000 km's
2006 Lexus ES 330 V6 VVT-i (225 HP, 250 ft/lbs) Premium Luxury, Sport, Navigation with Mark Levinson , 140,000 km's
camry6 is offline   Reply With Quote
Old 01-03-2011, 10:05 AM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Pull one of your spark plugs off and put a long straw down the spark plug tube. If its exactly TDC the straw will touch the top of the piston. This is a useful method when trying to determine the compression stroke too
Old 01-03-2011, 11:38 AM   #4 (permalink)
Note: Pull the spark plug from #1 cylinder. #1 cylinder is at TDC when the crank marks are aligned. This is always the reference cylinder.
