Hey everyone, I have a few days to try to figure out the car before school starts. Here is everything that is going on with the car.
The biggest problem I encounter is when the weather is cold, and I start the car, the car turns over but immediately dies unless I rev the car and warm up the engine. Once I rev/hold the RPMs at around 2k-3k for a few minutes, the idle will drop back down to around 500 and I can drive normally. The idle stays at around 500 rpm and feels a little low. If I turn the AC on, the idle will bounce slightly below 500, to around 400 then back to 500 then to 400 and I can hear a clicking sound.
Before the 500 idle, and before I disconnected/reconnected the battery because the car sat for 2 weeks when I was on vacation, the engine would do something else. Same cold start problem but from time to time, the car would idle at around 1800-2000 rpm. If I put the car in neutral, the car idles at 1800-2000 rpm, and sometimes if I drive it for a while it will go back to normal but most of the time it idles there. If I put it in drive, the idle stays at around 1,100 and 1,200 rpm. Other times, the car would rev on its own, and fluctuate between 1200-1800 rpm and keep bouncing the needle.
I read in another forum that I frequent with someone else having the same problem, and wanted to try some things first.
http://i-club.com/forums/showthread.php?t=224931
I was going to buy MAF cleaner but I couldn't locate the MAF sensor. Does my 1996 Camry have a MAF? If not, should I try cleaning the throttle body with throttle body/intake cleaner? In order to clean the throttle body, do I just need to disconnect the intake hose to the throttle body and spray the cleaner on? I'll read the directions on the bottle, just wanted to get an idea.
Also, the person at Advance Auto Parts took a look under the hood since he was outside helping another customer, and said I should set the idle higher by adjusting the idle screw but not sure if that's the problem. Thank you so much for any help. This forum has been so great in helping me with my problems.
