Symptoms of my car not starting... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2011, 07:45 PM   #1 (permalink)
View WetWilly80's Photo Gallery
Hey I'd appreciate any suggestions and explanations for what may be going on with my '94 auto transmission Camry.
My car often won't start. The headlights turn on and I have power inside the vehicle, but when I turn the key the clock dims to black. There are about 5 clicks each time it doesn't start, which makes me think the starter is fine. This has been happening for months but very infrequently until it got really cold a few weeks ago.
The key symptom I noticed this last time was that the interior display does not light up with the gear position. The gear shifter goes P-R-N-D-3-2. First I pulled back on the shifter when the car was in 2. The gear light glowed on the dashboard. Then I moved up each gear until I got to neutral. When I applied pressure to the shifter (towards the trunk) the gear light glowed and I could start the car in neutral.
As I progress to Park, it takes more downward pull to get the gear to light on the dashboard. When in Park I cannot start the car because the gear lights only as I begin to shift to neutral.
Thoughts??? Is this a switch, a loose cable, or my whole stinkin transmission system? The gears don't slip when driving...
Thanks.
HK
WetWilly80 is offline   Reply With Quote
Old 01-05-2011, 06:23 AM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Neutral safety switch sounds messed up. Do a search... the topic has been covered before. If needed, I believe Mr. Perkins did a DIY on repair as well.
'07 Honda Ruckus Big Bore
Old 01-05-2011, 09:04 AM   #3 (permalink)
92 Camry 5S-FE
LittleWhiteBubble's Avatar
Gameroom cash: $115750
View LittleWhiteBubble's Photo Gallery
If the switch was messed up the starter wouldnt click. Sounds like just a bad battery to me. Even if the battery tests good it can have a bad cell, and the cold will effect it more. The light in the dash is just tempermental sometimes because the contacts in the shifter get dirty. Mine rarely lights up.
LittleWhiteBubble is offline   Reply With Quote
Old 01-05-2011, 09:19 AM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Since your gear indicators are not lighting up, I would suspect faulty NSS Contacts.
Try this link:
DIY: Neutral Safety Switch Cleaning
