When I bought the car at 92k, I changed the PS flud with Valvoline Dex in the red jug. I believe its a syn blend. I used the DIY found on this site to do it. I plan on changing over to Royal Purple in the trans in a couple months (using the same stuff there).... Of course, Ive done oil changes, new struts, brakes, air filter, plugs (NGK), wires, valve cover gasket, etc. Cleaned the TB also. This car runs amazingly smooth, better than any domestic Ive ever owned. (Im going to try and trade off my F150 for a Tacoma at tax time...)
I will take it to the carwash with the degreaser as suggested to see if I can pin the leak down. Maybe I'll get lucky and not have to sacrifice my first born for a new rack. LOL. What should I avoid in the engine bay with the hose? cover the alt, fuse box. What else?
As far as the trans fluid, I agree there should have been more. When I topped it off, it was closer to 2 qts, but no where near the 2.6 qts TN says should drain out. At 92k I pulled the pan, changed gasket/filter, filled it up and drained it 3x. Now at 117k it seemed to be shifting a little harder lately, thats what prompted the recent fluid drain. The drain fluid wasnt bad, red but not pink, but the shifts did seem to smooth out some.
97 Camry LE 5SFE 135k
94 Corolla 1.6 @ 215K
97 F150 xlt v6 120k
92 Accord 4cyl 127k (totalled 8.4.11 by semi)
