DIY: 5sfe Oil Pump Diagnosis - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2011, 12:24 PM   #1 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
3rd Generation DIY: 5sfe Oil Pump Diagnosis
If you are experiencing low oil pressure, there could be multiple things to account for that but I am going to show you how to determine if the oil pump is good or not.
Tools needed:
10mm socket / ratchet
12mm socket / ratchet
Flat head screw driver
Snap Ring Pliers
Show towels
Motor oil
First thing first is to get to the oil pump and remove it. You need to remove the timing belt, exhaust, oil pan, oil strainer then the pump will come off. Its pretty extensive but once you get the oil pump off the following guide will help you determine if the pump is good, or needs replaced.
Heres a blowup to follow. If you forget what part i am talking about, refer to the following image:
Once you get to the pump, were first going to remove the oil pump body cover. There are nine 10mm bolts holding the pump body cover to the oil pump.
After pulling the Oil Pump body cover off, Remove the pulley by either using the SST 09616 – 30011 or you can fit a flat head screw driver in there and break the nut loose. The nut is 12mm.
Once you get the pulley removed it should look like the following picture. Note: I've also included a part number in case you want to replace the seal. As you can see the seal in the picture is bad and was leaking
Heres a few pictures of removing the seal:
Pull the drive rotor out from behind the Oil Pump Body cover and place it into the oil pump housing and using a feeler gauge measure the gap between the Driven rotor and the oil pump housing and also between the Drive and Driven Rotor. Specs are listed on pictures:
Flip the oil pump body over and remove the Snap ring (C-Clip), spring, and Relief Valve.
Apply a light coating of oil onto the Relief valve and re-insert it into the body. It should fall under its own pressure to the bottom. If it doesn't fall, first try to clean the inside of the tube the relief valve rides in with parts cleaner and a shop towel. Pour a small amount of oil into the tube and try it again. If it still doesn't drop, replace the relief valve. If a new relief valve doesn't work, replace the entire assembly.
Here is a run-down of all the parts for the oil pump:
EDIT:
Once you are ready to put the pump back together, make sure to put some petroleum jelly inside the Driven Rotor (Where the Drive rotor fits inside). It will help your pump prime quickly
The Following 6 Users Say Thank You to Mister_Perkins For This Useful Post:
71Corolla (01-06-2011), ajkalian (01-06-2011), houra (11-11-2011), JohnGD (01-06-2011), peshwa (01-06-2011), zythr (01-06-2011)
Old 01-06-2011, 12:40 PM   #2 (permalink)
Gameroom cash: $117250
View ty**20's Photo Gallery
great DIY. very detailed. will be very helpful for other wanting to repair oil leaks. keep them coming.
2000 Toyota Camry LE V6 IMZFE
ty**20 is offline   Reply With Quote
Old 01-06-2011, 12:44 PM   #3 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
Very, very nice DIY.
I vote for sticky.
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is offline   Reply With Quote
Old 01-06-2011, 01:03 PM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
More gold by Perkins... stickying.
'07 Honda Ruckus Big Bore
Old 01-06-2011, 09:49 PM   #5 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
TREMENDOUS work Perkins...are you an auto school student or what?? lol...I would love to work on my car all day but I gotta earn something too
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 01-06-2011, 10:47 PM   #6 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
So when priming the oil pump before installing the motor, are you supposed to pour the oil into that valve relief hole? I'm not sure exactly which hole is best suited for doing that...
RichieRichJP is offline   Reply With Quote
Old 01-07-2011, 08:11 AM   #7 (permalink)
No, you pack the drive and driven rotors with petroleum grease. You put oil onto the relief valve to make sure its working properly. "Dropping under its own pressure". It wont work to try to put oil into the relief valve hole because the oil will just pour out the hole above the relief valve. Just use the petroleum grease on the two rotors when you re-install the pump
I was an auto school student back in 2006 (UTI)
Old 01-07-2011, 10:18 AM   #8 (permalink)
Oh ok. I thought you were talking about it there, but wasn't entirely sure.
Thanks for the writeup!
Tags
5sfe, 5sfe oil pump, oil pump
