DIY: 5sfe Distributor Diagnosis - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2011, 09:11 AM   #1 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
3rd Generation DIY: 5sfe Distributor Diagnosis
Tools Needed:
12MM Socket
Extension
Ratchet
Feeler Gauge
Phillips head screw driver
Digital Multimeter
First Remove the distributor. Disconnect the pigtail harnesses from the distributor (2), and remove spark plugs from motor. (This step is kind of important to easily remember firing order .. keep them attached to the distributor cap).
After removing harnesses and spark plugs from motor, there are two 12MM bolts holding the distributor in place. Remove both bolts and pull distributor out.
there are three Phillips screws holding the distributor cap. Remove all three of these and pull cap off. Remove the rotor, and plastic housing covering the coils.
Take a few seconds to inspect the distributor cap. Look for cracks and the over all condition of the cap. If cracked, or looks damaged replace the cap.
Grab your digital multimeter and measure the resistance of G1 and G Pins. Resistance cold should be 185-275 ohms.
Next, measure the resistance of the NE+ and NE- pins. Resistance cold should be 370-550 ohms.
If either the G or NE pins are not within spec, replace the Distributor housing.
Next, we are going to measure the air gap on the pickup coil. Grab your Feeler gauge, and place it between the pickup coil projection and the signal rotor. Air Gap should be between .02mm - .04mm (0.008in. - 0.006in.)
If air gap is not within spec, replace the distributor housing.
Addition:
Checking the Primary and Secondary Coils on distributor:
Using a multimeter and the chart below, measure the resistance on the primary coil and secondary coil (Pictured below)
Primary Coil
Secondary Coil
The Following 3 Users Say Thank You to Mister_Perkins For This Useful Post:
bcny168 (04-30-2012), Luckynumber5 (01-07-2011), Osagecoon (03-23-2011)
Old 01-07-2011, 10:19 AM   #2 (permalink)
engineer in training
Gameroom cash: $145055
AHa, nice as usual The resistance tests can be VERY handy for diagnosing frustrating problems.
Luckynumber5 is online now   Reply With Quote
Old 01-07-2011, 01:34 PM   #3 (permalink)
View sabbates's Photo Gallery
Do you have to mark the rotor before removing the distributor?
Won't the timing be messed up if you don't?
sabbates is offline   Reply With Quote
Old 01-07-2011, 01:44 PM   #4 (permalink)
No, you just have to set the motor to TDC and set the rotor to Spark plug #1 before cranking it.
Most caps are labeled with the rotor cap:
Old 01-08-2011, 09:57 AM   #5 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
*Says to self* It sure would be sweet if there was a DIY with the complete seal replacement
RichieRichJP is offline   Reply With Quote
Old 11-01-2011, 03:08 PM   #6 (permalink)
Hoosier Daddy
View NapalmFTW's Photo Gallery
Resurrecting this thread.. but when reinstalling the dizzy should there be RTV on the mating surfaces? The previous owner/mechanic has tried to solve an oil leak by coating the distributor mating surface with RTV.
NapalmFTW is offline   Reply With Quote
Old 11-02-2011, 02:07 AM   #7 (permalink)
No just lightly lube the o ring. If it leaks that o ring may be the culprit
Old 04-29-2012, 12:37 PM   #8 (permalink)
View tedmich's Photo Gallery
nice write up, good (BIG!) pictures, BUT I believe the air gap is 0.4 – 0.2 mm (0.008 – 0.006 in.), as 0.02mm would be very hard to measure!
tedmich is offline   Reply With Quote
Tags
5sfe, 5sfe distributor, distributor, distributor test
