A few weeks ago, i was looking into getting a new car, deffiantely toyota. My camry has 312,000 miles, and whiles its been nothing but good to me, its starting to have its issues. After a few Pm's, i found my car. J_tex's 96 coupe. I wont reveal what i paid, because id say its a score
. Anyways, in late november, it was in a crash. Thats where the
rebuild comes in.
Before the crash:
After the crash:
As you can see, the drivers side fender, Corner light, headlight, front bumper and the directional are all junk. What you cant see, is that theres a little more underneath, most of the fender and bumper supports on that side are no-good, aswell as the headlight housing, and parts of the frame are bent.
THis is the good side of the frame:
And the bad side:
This is after my teardown of the front end. It turns out that the passangers side fender is junk aswell.
I have my plans for the frame, using my comealong, ill hopefully be able to bend it back into its orignal postion. If you look closely, you can see that the radiator is sitting slightly higer on the right. the support above the radiator/headlight needs to be pulled down too. That, in addition to a few smaller things should take care of the frame.
The fenders/bumper/lights/etc are a different story. Since this is a 96, and my old sedan is a 94, everyhting will swap right over
Anyways, i have a few plans for her...
-Replace the front end, using my current camry as a donor car (gen3 facelift? haha)
-replace deployed airbag/cover. Does anyone know if i can bend the stock airbag cover back?
-He threw in some lowering springs, i need to install the rears. 2in ones.
-Pull engine, for a few reasons, mainly to remove a coupe of mounts and parts i want to sandblast, like the header, valve cover, etc.
-Come spring, ill have the new front end painted to match. However, while the engines out, im going to clean up the bay, and give it a coat of HT primer, and a coat of a paint similar to rhino-liner, just for some extra durability/fun really.
Im in school, and class is over, ill update later!
oh, by the way, its a standard
Peace
Eric N
