How to test the rad fan (properly) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2011, 01:25 PM   #1 (permalink)
View nmik's Photo Gallery
I am having problem with overheating after a strange event that I wasn't a witness to. My son was driving the car when it started misfiring and died. SES light came on and then disappeared after engine was restated and ran fine. I tried cleaning EGR system but had no access to the lower portion of the steel pipe so I never got to really cleaning it. Now it overheats even idling. Radiator fan dos NOT come on.
I'd assume I could hotwire the fan and see if the fan itself is functioning but it will not diagnose the relay or sensor or wiring. Is there a niftier way to diagnose the system?
Thanks!
nmik is offline   Reply With Quote
Old 01-07-2011, 01:39 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Well, assuming no fuses are blown...there is a fan temperature switch at the bottom of the radiator. unplug it, and start the car. If the fans start running as soon as you start the car, then the problem would be that switch.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
The Following User Says Thank You to uibalnme For This Useful Post:
nmik (01-07-2011)
