25°F only about 1/4 warm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2011, 10:36 PM   #1 (permalink)
Gameroom cash: $177500
View ShawnTRD's Photo Gallery
Ok on the way home tonight from a friends I drove about 6 miles mostly downhill costing around 25°F out, and the temp was only about 1/4 up from C. I've notice normal driving temp seems to be just blow 1/2. So do you think the thermostat is stuck open?
ShawnTRD is offline   Reply With Quote
Old 01-08-2011, 02:17 AM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260040
View Yuko's Photo Gallery
Does the temperature ever reach normally after a while? I'm almost 100% sure the thermostat is stuck open as you suggested. My father’s 1995 Quest has been stuck open for two years and it takes 15 minutes to fully warm up (needle at normal) Freezing to drive. Just drain the coolant, replace the thermostat with a new one (many recommend OEM) refill with coolant, turn on the heater, start the engine, check for leaks and temp, and top off if needed.
"Yūko" 2001 Camry 5S-FE/A140E @ 90k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 156k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 2K
Yuko is offline   Reply With Quote
Old 01-08-2011, 11:34 AM   #3 (permalink)
JDM Inspired
Spitfire's Avatar
Gameroom cash: $122390
View Spitfire's Photo Gallery
^ do what he said. yeah its your thermostat. i just replaced mine about 2 weeks ago. and note this to get the the bottom bolt that holds the thermostat housing in place you will prob have to take off the oil filter unless you have a fancy wrench of the sort. haha
Spitfire is offline   Reply With Quote
Old 01-08-2011, 06:03 PM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Guys, keep FSM chatter to PMs please! I won't lock this thread, but someone else higher up might have a different opinion.
'07 Honda Ruckus Big Bore
Old 01-08-2011, 08:05 PM   #5 (permalink)
Gameroom cash: $814501
View zythr's Photo Gallery
What is FSM?
zythr is offline   Reply With Quote
Old 01-08-2011, 08:17 PM   #6 (permalink)
Freakin Scooters
Factory Service Manual.
The Following User Says Thank You to LynchburgCSI For This Useful Post:
zythr (01-08-2011)
