1994 Camry LE 2.2l engine wiring harness interchange? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2011, 07:49 PM   #1 (permalink)
View cjean99's Photo Gallery
I bought a 1994 Camry LE 2.2l automatic, 4-door that had an engine fire. We need to replace all wiring under the hood. Have gotten different opinions on what engine wiring harness can be used. Can we interchange with different year Camry, or only 1994? Can it be from other than LE? Any help is appreciated.
cjean99 is offline   Reply With Quote
Old 01-08-2011, 07:57 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
check ebay. best would be if you knew your part number (Engine Wiring) used on your model. this way it could be cross-referenced with other years/models.
toyodiy.com lists a bunch of possible part numbers depending on an exact manufacturing date and emission specs in 1993-1995.
http://www.toyodiy.com/parts/p_U_199....html?hl=82121
best to call the dealer's Part Counter and let them give you the part number (with price estimate hehe) per your car's VIN.
Old 01-08-2011, 08:53 PM   #3 (permalink)
wiring harness
many thanks - will try that.
Old 01-09-2011, 09:04 AM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
95-96 harness, computer, NSS, transmission is different from 92-94. Any harness from 92-94 will work
Also, I have a complete harness from a 92 Camry LE (AT) if your looking for one
Old 01-14-2011, 09:03 PM   #5 (permalink)
Great info - thanks! I live in Council Bluffs, Iowa. Would like to get a harness, but depends on price and shipping cost. Son may end up at U-Pull-It. We are going to have to replace headlights, radiator, fans, possibly starter. Not sure what else yet. Waiting until spring when it's warmer to finish taking out everything that burned.
Old 01-15-2011, 09:02 AM   #6 (permalink)
I could do $70.00 + shipping if that sounds feasible.
I also have everything you listed too
Old 02-05-2011, 05:57 PM   #7 (permalink)
Found a 94 Camry LE auto with engine/tranny trouble for $450 entire car. Should work fine. But thank you again for info and offer!
Old 02-05-2011, 05:58 PM   #8 (permalink)
No problem .Hope it works out for ya
