novice with question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2011, 01:00 PM   #1 (permalink)
chh
View chh's Photo Gallery
My 1998 Camry has very dull headlights making driving at night difficult. Should I replace bulbs or have alternator checked first? Plastic covers are clear still. Thanks.
chh is offline   Reply With Quote
Old 01-09-2011, 01:08 PM   #2 (permalink)
Gameroom cash: $303755
If your car is starting on cold mornings, your alternator is probably OK. I would still have it checked out since places like Autozone will check the battery and charging system for free. Since you say both headlights are dull, and bulbs usually just burn out rather than go dim, I would suspect a grounding problem. Check all grounds that lead to the headlights for corrosion.
Mike
Old 01-09-2011, 02:11 PM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
I doubt it's any electrical problem. The headlights on these generations of camry SUCK. In a perfect world, i'd suggest a projector retrofit. But that costs hundreds of dollars. So, as a cheap fix, look into getting HIR bulbs. NOT NOT NOT HID BULBS. Search around the forum for more info on them. You might also want to insure that's there's zero yellowing on the headlight lens as well.
'07 Honda Ruckus Big Bore
Old 01-09-2011, 02:43 PM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
I polished up the lenses to remove the clouding, then put in some Sylvania Silverstar halogens. It improved the headlights a lot, made them acceptable. I agree, the factory headlamps on these cars are terrible.
71Corolla is online now   Reply With Quote
Old 01-09-2011, 02:57 PM   #5 (permalink)
Avy
Gameroom cash: $818555
View pmesfun's Photo Gallery
+1
Before:
After:
Wetsand (with soft grit) and polish the headlights.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
