Hi folks,
Thought I'd update this thread. It's been a while... a long while... but I got the car sorted in the end.
The problem was, as usual, a compound of different things. Basically it needed 4 new glow plugs, new injectors, and an injector pump. Basically the engine wasn't holding compression to generate heat caused by an under powered pump (injectors were replaced too as a pro caution but I've put them back in to satisfy my curiosity - and they work fine) the issue was compounded by the heater plugs being wasted and not generating heat at start. Oh and it was really cold this winter in Armagh
So new injector pump and plugs seem to have done the trick. A lot less smoke (only on heavy acceleration) and starts every time as well as having a constant idle speed. Plus my MPG is back into the 30's (UK MPG that is)
Anyway, thanks for your posts and suggestions, I hope to have this car going for another couple of years yet now
