Hello everyone!
I'm new here and need your advice,please!
Here is a problem: I have 1997 Toyota Camry,180k,V6,3.0,Autamatic.
The problem is a fuel leak,not always but sometimes.
I try to show you on a pictures what I mean.
There is some valve,covering with plastic cap,I don't know how exactly it call,(I point it arrow) located on upper manifold,and its fuel leaking.
Please,tell me how it exactly call,valve or fuel pressure valve or something else?
Thank you very much!
On my 2000 1MZ-FE it's called a FUEL PRESSURE PULSATION DAMPER ASSY, and the part number is 23270‑62010. Your's might be a different part number, though. It's a bit pricey at around $90.00 so you might want to check your local Pick-N-Pull.
EDIT:
Oops, I was wrong on the price. Here's a link to the part, and see if you model is included.
Thank you!
Where can I find a gasket/washer?Napa,AutoZone or dealer?
Yes,I'm sure,a fuel is leak so much from plastic cover.Its a lot of fuel,and I'm really scared driving until fix this problem.
Don't drive with a fuel leak, that is extremely dangerous. I got them front eh dealer today. They are around $1-2. Make sure you pinpoint the leak first.
don't drive with a fuel leak, that is extremely dangerous. I got them front eh dealer today. They are around $1-2. Make sure you pinpoint the leak first.
thanks man!
1997 Toyota Camry XLE, V6, 1MZ-FE, 180,000 miles.
I'd assume the torque spec here is VERY important. Sadly, I don't know the specific number.
'07 Honda Ruckus Big Bore TOTALED: '03 Ford Expedition Eddie Bauer 4x4 5.4L, '96 Camry LE 5S May '10: '11 Sienna V6 XLE FWD 8-pass. July '10: '06 Matrix XR Auto FWD Oct. '09: '05 RAV-4 L 4WD
Well,I'm trying to remove it buy wrench and just can't do it,its tighten very well.
Trying to remove 14mm bolt and stop it because of fuel pressure.Is it normal?
if you haven't released/lowered the fuel pressure in any way then yeah there might be some.
normally you idle the car and while engine running you open the main fuse box under hood on driver side and you pull out the blue 15A EFI fuse letting the car die (it's instant).
then you turn the IGN OFF and open the fuel cap on gas tank to release vapor pressure (or vacuum or whatever there is).
this time fuel pressure should be a fairly brief squirt of fuel and nothing more maybe a few more drops later.
I don't know the torquing spec for that banjo bolt, using a torque wrench on it would be another thing. just make it hand tight and check for leaks later. those gaskets can be re-used normally as they are metal, unless damaged.
WOW! Thank you!!!
if bolt is not loose and making it hand tight didn't work then replacing those gaskets would make sense. also make sure that the leak is not coming from one of fuel injector grommets (on the fuel rail side) and flowing towards the pulse damper.
