Timing belt water pump kit question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2011, 11:40 AM   #1 (permalink)
View racerized's Photo Gallery
I have a 1996 camry with a 2.2L 5sfe. I am getting conflicting info on kits. Some say model specific and some list multiple( camry,mr2,rav4). Is a kit universal? Any I'd to would be great. My camry either snapped the belt or lost the tensioner. Any kit recommendations?
I'm looking for the following:
timing belt
water pump with gasket
timing belt tensioner
timing belt idler
timing belt tensioner spring
valve cover gasket set
spark plug tube seals
accessory drive belts
thermostat
thermostat gasket
crankshaft seal
camshaft seal
oil pump seal
oil pump o ring
Cam cover gaskets
Thanks
Keith
racerized is offline   Reply With Quote
Old 01-11-2011, 11:47 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Get OEM parts
Gary "on this forum" can get everything you need (OEM) with a discount
Old 01-11-2011, 12:11 PM   #3 (permalink)
View camry6's Photo Gallery
Canada
timing belt
timing belt idler
thermostat
thermostat gasket
crankshaft seal
camshaft seal
oil pump seal
oil pump o ring
Cam cover gaskets
Thanks
Keith
Yea, I agree with Mister Perkins. If you are planning on keeping this car, and want to ensure reliability, Go with Toyota parts. You really don't want to "cheap out" on your cars engine. In fact, Toyota parts are sometimes less money than aftermarket, that's what I have found at least. Even if the Toyota parts cost much more, you will be assured that the quality is in it and you will maintain the reliability. There have been some very frustrating situations discussed on this forum as a result of using aftermarket parts.
1993 Toyota Camry V6 LE (200 HP, 195 ft/lbs tweaked) , 430,000 km's.
2002 Lexus GS 430 V8 VVT-i (300 HP, 325 ft/lbs) Luxury with Mark Levinson , 156,000 km's
2006 Lexus ES 330 V6 VVT-i (225 HP, 250 ft/lbs) Premium Luxury, Sport, Navigation with Mark Levinson , 140,000 km's
camry6 is offline   Reply With Quote
Old 01-11-2011, 06:19 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
I agree, go with all OEM parts (with online dealer discounts reaching 30% off MSRP) or get a very similar kit only aftermarket brands (no Toyota logos on parts) often much lower as most parts are same as OEM, same manufacturers - look for them on ebay.
Old 01-11-2011, 07:25 PM   #5 (permalink)
View DTB500's Photo Gallery
This kit is on Ebay and it is OEM stuff made by Aisin.
It's the one I am going to buy when I change my belts/pump. I agree with the previous posters who recommend going with OEM parts unless you are planning on selling the car soon.
\http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.m748&item=270 691293428&viewitem=&_trkparms=clkid%3D630415264260 9339493
DTB500 is offline   Reply With Quote
Old 01-11-2011, 07:42 PM   #6 (permalink)
Avy
Gameroom cash: $818555
View pmesfun's Photo Gallery
+1
I used that kit also.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 01-11-2011, 08:09 PM   #7 (permalink)
I'm a Newbie??
View SpeedyTurtle's Photo Gallery
Nice info guys! I want to do this type of job, but I'm hesitant i will just make things worse. Anyone know some reliable mechanic in north new jersey for a timing belt job?
Still Running 95 Camry Coupe 195K miles and counting!
* 07 Camry SE *
Sold:
http://www.cardomain.com/ride/2305449
RIP 00 Toyota Celica GT, 00 Maxima SE
SpeedyTurtle is offline   Reply With Quote
Old 01-11-2011, 08:18 PM   #8 (permalink)
Canada
Buy yourself a Haynes service manual and dig in. It's relatively easy, don't be afraid to get dirty!
Old 01-11-2011, 08:32 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
no. I don't trust any of them. eventually had to do this myself to get things done right
as above, DIY and get some dirt under your nails ... that of course if you have a garage ... if not then I hope the weather stays clear and warm at your place ... which is unlikely ... we have an oncoming blizzard
to tell the truth. I used a local shop around me 2 times (cheap aftermarket parts didn't pay off first time). nothing leaks, all works ... but it wasn't a perfect job, so I don't recommend them. they are sloppy. Most other shops around here are so shady I wouldn't trust most places with a tire rotation ... and on top of all most of them just thinks of raping your wallet
Old 01-12-2011, 11:41 AM   #10 (permalink)
Right now I'm not sure if I can swing Toyota parts. I found this one but it says it's for a mr2 with a 5sfe. Will this work? What's the difference between mr2 kits and camry kits?
Amazon Amazon
Old 01-12-2011, 02:49 PM   #11 (permalink)
Canada
http://www.amazon.com/gp/aw/d.html/r...5?a=B0038A19IQ
Check out this kit on ebay, it fits 1992 to 2001 Camry with the 5S-FE engine. This will have everything you need for the timing belt/waterpump service. A great price too! These components are AISIN Japan, except the timing belt which is made in USA. They are what you get from Toyota, (except the belt) with the Toyota emblem removed. These parts will have the same quality as if you bought them from Toyota, except the price is about 1/2 the cost!
Just click on this link!
http://cgi.ebay.com/ebaymotors/Aisin...#ht_3257wt_941
Old 01-12-2011, 02:58 PM   #12 (permalink)
抵抗は無駄です
fenixus's Avatar
that above kit fits those:
1987-1991 Toyota Camry 3SFE 2.0 4cly DOHC
1992-2001 Toyota Camry 5SFE 2.2 4cly 16v DOHC
1987-1989 Toyota Celica 3SFE 2.0 4cly DOHC
1990-1999 Toyota Celica 5SFE 2.2 4cly 16v DOHC
1990-1995 Toyota MR2 5SFE 2.2 4cly 16v DOHC
1996-2000 Toyota RAV4 3SFE 2.0 4cly DOHC
1999-2001 Toyota Solara 5SFE 2.2 4cly 16v DOHC
so essentially any 90-95 MR2 kit would fit a camry 5s-fe 92-01 application as well.
it even fits 3s-fe application
there is also another OEM kit on ebay for a 98-01 camry:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
double price, all OEM suppliers as well and you get cam and crank seal, water pump with housing (Aisin), gaskets and o-rings, idler (Koyo), tensioner (Koyo), thermostat (Kuzeh would be OEM but Motorad wasn't called same as OEM by a fellow TN member) and both OEM drive belts (Bando).
or this one for 87-96 camry:
http://cgi.ebay.com/ebaymotors/Fit-1...Q5fAccessories
Old 01-12-2011, 04:22 PM   #13 (permalink)
Out of the 2 aisin kits what's the difference between the tkt002 and tkt003? I must be missing something. Maybe I'll do an aisen kit and get the rest from toyota (Gary)
Thanks
Old 01-12-2011, 04:56 PM   #14 (permalink)
Avy
That is what I did.
I copied this from Aisin Aftermarket website:
TKT-002 Engine Timing Belt Component KitToyota Camry (Car) 1996 2.2L L4 2164cc; w/ 5SFE Desig.; Kit Contains Water Pump With Housing- http://cgi.ebay.com/ebaymotors/Aisin...Q5fAccessories
TKT-003 ENGINE TIMING BELT COMPONENT KIT Toyota Camry (Car) 1996 2.2L L4 2164cc; w/ 5SFE Desig.; Kit Contains Water Pump Without Housing- http://cgi.ebay.com/ebaymotors/Aisin...Q5fAccessories
99 Avalon XLS-149k
99 Lexus LS400-88k
