Gas door does not spring open any more - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2011, 01:30 PM   #1 (permalink)
View nogard's Photo Gallery
Does anyone have a picture with their gas door open?
It looks like there was a plastic tab that used to spring the door open. This is broke and the door doesn't "pop" now.
Anyone else come across this? What was your fix? I may have to add a spring, or a small piece of spring steel.
Thanks.
nogard is offline   Reply With Quote
Old 01-11-2011, 01:41 PM   #2 (permalink)
View kcmobmx's Photo Gallery
Thanks.
look inside the door and you will see a black plastic tab. the spring is broken off. you can get them at your local Toyota dealers for about 5-7 bucks and it takes like 30 seconds to install, not a big deal.
kcmobmx is offline   Reply With Quote
Old 01-11-2011, 01:54 PM   #3 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $324600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
very common problem with a very easy fix. like kcmobmx said, it takes like 30 seconds to fix. $4.60 MSRP.
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 01-11-2011, 09:41 PM   #4 (permalink)
shipping expert
rhelinger23's Avatar
View rhelinger23's Photo Gallery
mine broke about 2 weeks ago... I got the replacemet part at my dealer for about $3 (they usually keep it in stock) and it just pops right on.
98 Camry LE 5S-FE 81k 5-speed
rhelinger23 is offline   Reply With Quote
Old 01-12-2011, 12:33 AM   #5 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260040
View Yuko's Photo Gallery
Just in case anyone need pictures. Here's some from my Gen 4. There are really no instructions for it; just pop on and off. I did however have to open the filler door/cap at 45 degree to pop the clip off from the hinge. Then slide it out and it'll fall off. The new one go on reverse order; slide on, pop in. I think the part number is 77360-33020.
You can see the spring on the hing (brass color)
"Yūko" 2001 Camry 5S-FE/A140E @ 90k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 156k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 2K
Yuko is offline   Reply With Quote
Old 01-12-2011, 09:10 AM   #6 (permalink)
Thanks for the information. Time to go shopping at the dealer. I rarely go there, except for things like this. I don't mind, there is a older gentleman that works at the parts counter and is great to deal with.
Old 01-12-2011, 11:05 AM   #7 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
