5S-FE Water Pump: Mystery Gasket and O-Rings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2011, 05:19 PM   #1 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260040
View Yuko's Photo Gallery
Thanks for all the DIYs that you guys have provided on TN. .
I have set time tomorrow to replace my water pump and timing belt before the second semester of college starts. I can’t afford all OEM parts so I got a new O’reilly Water Pump $35, Felpro gasket $3, OEM Tensionor spring $5, and a Gates timing belt for $18. The problem is in the water pump box; there is a extra gasket, o-rings, and a bolt that I have no idea where it goes. I search on TN and Google but no one mention about these parts. Are they for a different application?
You can see the extra parts in the bag.
The guy at the part store told me that the bolt should screw into one of the threaded holes (red arrows) Why are they there? But I think it's to replace one of the seven bolts on the old water pump.
Don’t worry; I got a blue Felpro water pump gasket but a bit confused about these extra parts in the box. I want to do it right the first time but on a tight budget. Maybe I should have bought the oil seals but I think the engine is still young. Thank for any advises and tips.
"Yūko" 2001 Camry 5S-FE/A140E @ 90k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 156k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 2K
Yuko is offline   Reply With Quote
Old 01-11-2011, 05:30 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Originally Posted by Yuko View Post
I can’t afford all OEM parts...
You won't like this, but unless you plan on selling your car shortly, it will cost you more in the long run.
As for the gaskets, there are two O-rings for the water pump, you will see them when take things apart. The smaller one goes on the water bypass pipe. Below that is where that small gasket goes with the two holes in it.
Do you have a new thermostat and gasket?
edit - there are differences between years when it comes to the 5SFE, so you may or may not need a gasket that is included with the water pump, which will fit on may different year Camry's. Here's a diagram for the 3SFE, which is slightly different than what you have but you get the idea.
71Corolla is online now   Reply With Quote
Old 01-11-2011, 07:32 PM   #3 (permalink)
Yuko's Avatar
Thanks for the diagram. The gasket and o-rings dose go to the by-pass pipe. I guess most people leave that alone. With further searching, One of the bolt on the water pump is a screw and I guess the one in the bag is the replacement for it.
Haha, I knew someone will tell me that. The risk of early parts failure does not out-weight the time and labor. I know I should replace the cam, oil, crank seal, tensioner, idler, ect. But I need to save money for new text books this semester. I'll gamble and skip the seals for now. I also don't want try to replace it and cause it to start leaking.
I will be flame on for this. I'll skip the thermostat and recycle the coolant too. *I can hear yelling* I plan at first to drive until the belt snap and replace anything, but the last place I need the belt to fail is (A) on the highway and (B) on the way to class for an exam. I'm just doing this to get me pass the next 4-5 years.
Old 01-11-2011, 08:38 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The fiber/paper gasket will need some Permatex water pump RTV, or it will seep coolant later.
When was the last timing job on the car? Were the seals and pulleys replaced?
Old 01-11-2011, 09:10 PM   #5 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Four to five years.... Oh mannnnnn. You already know what I'm gonna say Yuko, so I won't say it.
'07 Honda Ruckus Big Bore
Old 01-11-2011, 09:27 PM   #6 (permalink)
Avy
Gameroom cash: $818555
View pmesfun's Photo Gallery
I'm pretty sure you will be fine, depending on how many miles you average a year and driving conditions. Gates belt quality is good as OEM. Not sure about the water pump.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 01-11-2011, 09:46 PM   #7 (permalink)
Well if you gotta save money, you gotta save money.
But at least check for seepage around oil seals. Shake the pulleys and listen for clicking.
Old 01-11-2011, 09:49 PM   #8 (permalink)
Yuko's Avatar
Yea, I got the RTV for it already. This is the first this timing belt job on this car so it still have the original seals and pulleys
Well, not sure what you mean. I know my OEM timing belt have a service life of 90,000 miles under normal driving. When I meant 4 to 5 years, I just wanted to get my Camry going through college and after earning my Industrial Design degree and a career with a major motor company; then I can afford to have my Camry properly and fully serviced at Toyota with OEM parts. But for now, I needed to make sure my Camry can reliably get me from home to the university.
Also, I just got a front crank and oil seal kit from Fel-Pro for $7 but if it's not leaking, should I even touch it at 80,000 miles.
Old 01-11-2011, 09:59 PM   #9 (permalink)
By 100K or so the pulleys are usually quite noisy and can have some play. But if you still have factory parts on there then maybe you can wing it.
But with a Gates Timing Component Kit at $54+shipping on rockauto and oil seals adding another $20 or so. These will really help last the 4-5 years you need.
And agreeing with others, not really sure about the water pump however. What brand is the pump?
Old 01-11-2011, 10:01 PM   #10 (permalink)
Freakin Scooters
I was getting at the fact that all the parts mentioned in this thread SHOULD be OEM. Skimp on gaskets, and they may not last for 4-5 years. Felpro is a good brand though.
Old 01-11-2011, 10:12 PM   #11 (permalink)
Avy
I doubt there will be oil leakage, be careful when replacing the seals. The aluminum can be damaged easily.
I guessing its a MasterPro WP, the original WP will probably last longer.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 01-11-2011, 10:30 PM   #12 (permalink)
Yuko's Avatar
I do agree with all of you, OEM is the BEST . Sadly my wallet don't agree, so I have to settle for the aftermarket. Here’s the part listed.
Water Pump: O’reilly Master Pro Select New Water Pump: Assembled in U.S.A. of U.S. and foreign parts.
Timing Belt: Gates: Made In U.S.A.? (I’ll find out tomorrow when I pick it up)
WP Gasket: Fel-Pro: Made in U.S.A.
Tensioner Spring: OEM P/N 90507-17003: It’s Toyota so it had to be good right?
I think I’ll return the Fel-Pro Front Set Kit because they are a mix of Taiwan and Mexico (I’ll leave the original in…)
Old 01-11-2011, 10:34 PM   #13 (permalink)
Freakin Scooters
Sounds fine! The WP i'm a little weary of. But it has a warranty, right?
Old 01-11-2011, 10:35 PM   #14 (permalink)
Do you plan to use Toyota Red coolant with *distilled* water?
Old 01-11-2011, 10:39 PM   #15 (permalink)
Avy
I read somewhere in this forum that, on aftermarket wp you use green (prestone) coolant?
He said he is reusing the old coolant.
99 Avalon XLS-149k
99 Lexus LS400-88k
