Originally Posted by casey38boost
I am not sure if the car has run out of fuel, but I will check.
Should I clear the ECM and see what codes come back?
I would rather go one step at at time then replacing both front and rear o2 sensors if possible.
Thanks for the help
yeah, go ahead and clear codes first if you haven't already
most likely they all (maybe except P0171) return, some of them instantly if they persist, some others later (if still problem) as some of them require a 2 trip detection logic.
start with the rear bank AFR (bank 1 sensor 1), this one has a faulty heater most likely (reported heater circuit failure).
P1135 A/F Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) (Only for California Spec.)
the one in front (bank 2 sensor 1) still works but reports a Response Malfunction (not good either; I was wrong above about Slow Response), qualifies for a replacement too.
P1153 A/F Sensor Circuit Response Malfunction (Bank 2 Sensor 1) (Only for California Spec.)
either of above codes drops the ECU into a limp (fail-safe) mode. fuel system operates in an open loop only, computer doesn't trust any sensors and uses preset fuel maps.
possible that the rear (meaning post-cat, under car) one might be going bad slowly as well, so consider replacing all of them over time. total around $250 if you DIY, new original Denso OEM sensors (just no Toyota logos on them) from ebay seller or amazon store.
check your part numbers here:
http://www.densoaftermarket.com/catalog/
then look for them on ebay and amazon.
