3VZ O2/ECU question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2011, 04:07 PM   #1 (permalink)
Gameroom cash: $119055
View thaharlequin's Photo Gallery
3VZ O2/ECU question
If both upstream O2 sensors were disabled, would the ECU use the downstream sensor to help adjust fuel trim and keep the car near stoich, or does it just revert to open loop and run whatever the default maps says to?
thaharlequin is offline   Reply With Quote
Old 01-12-2011, 08:29 PM   #2 (permalink)
View camry6's Photo Gallery
Canada
It will run open loop until ALL sensors are working.
1993 Toyota Camry V6 LE (200 HP, 195 ft/lbs tweaked) , 430,000 km's.
2002 Lexus GS 430 V8 VVT-i (300 HP, 325 ft/lbs) Luxury with Mark Levinson , 156,000 km's
2006 Lexus ES 330 V6 VVT-i (225 HP, 250 ft/lbs) Premium Luxury, Sport, Navigation with Mark Levinson , 140,000 km's
camry6 is offline   Reply With Quote
Old 01-12-2011, 08:59 PM   #3 (permalink)
Good to know, thanks!
Old 02-15-2011, 02:22 PM   #4 (permalink)
I'm bumping this because it looks like, at least for CA versions, that it will run in closed loop to some extent even if the downstream oxygen sensor is the only one hooked up. I leaned out the AFM a ton (8 clicks or something), unplugged the two upstream sensors, and the damn thing surged like you wouldn't believe, presumably because the downstream sensor was detecting the lean condition and the ECU would richen the mixture, then back off as it got too rich. Rinse and repeat. I even had the cruise control on at ~60mph and I could feel it surging. When I unplugged all three w/ the AFM in the same position there was no surging at all.
