Magnaflow Muffler vs. OEM Muffler question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2011, 11:16 PM   #1 (permalink)
werkit217's Avatar
View werkit217's Photo Gallery
4th Generation Magnaflow Muffler vs. OEM Muffler question
Hey ya'll, it's been awhile since i've been in the forums. As a quick reminder I have a I4 98 Camry. So my muffler crapped out on me yesterday, so gonna get it replaced soon.
I'm looking to have a QUIET muffler, I don't care much for growling and purring on this car since I can get my fix from my other car. I don't care much for performance gains neither, I'm looking strictly for a better quality muffler than what a hole-in-the-wall muffler shop will install for me (most likely aluminum) in my daily driver.
I was wondering if any of you have a magnaflow muffler with stock cat installed? I was looking at this one
Amazon Amazon
Magnaflows are of great quality and S/S and can't beat the price, however not sure how much louder this muffler will be from OEM. Yes, I understand that if I want the quietness of an OEM muffler to simply buy another OEM one, however my question is for this Magnaflow for any smart alecs .
I build cars the way I build them, anybody who thinks any different, well... they're just wrong
werkit217 is offline   Reply With Quote
Old 01-15-2011, 11:26 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
It's still going to be louder than stock. Any muffler in the same class as Magnaflow will be louder than stock. Those no-name mufflers you find at small muffler shops are as close to OEM quiet as you'll get without getting an OEM muffler.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 01-16-2011, 01:15 AM   #3 (permalink)
engineer in training
Gameroom cash: $145055
You may have trouble installing that one, typically you install a resonator under the car and the muffler installs attached tot he tip, there isnt too much room to play around under the Camry chassis and that magnaflow looks like what youd install under a truck. The amount of piping after the muffler makes a difference in overall sound and some mufflers will be really really loud with less than a few feet of pipe at both ends. Go with a vibrant muffler or a good quality OEM type, Magnaflows are usually pretty loud...
Luckynumber5 is online now   Reply With Quote
Old 01-16-2011, 02:17 PM   #4 (permalink)
werkit217's Avatar
@Lucky I didn't even look at the dimensions of the muffler, that one is definitely for a truck .
Do either of you have a magnaflow installed on your camry?
Old 01-16-2011, 02:26 PM   #5 (permalink)
uibalnme's Avatar
I do. Yes, It's louder than stock. I can set off car alarms with the engine spinning at just 1500RPM. Not always, but sometimes.
Old 01-17-2011, 10:48 PM   #6 (permalink)
werkit217's Avatar
You have a gen 3 though, so possibly different results? So upon further inspection i have found that my muffler is perfectly fine, the mid pipe however rusted off its flange on the inlet side of the muffler.
Rather than to have the muffler shop fix that and possibly another few spots closer to the resonator, i'm going to replace the entire midpipe and resonator. I'm going to check ebay and amazon, the pipes are probably $100 or so
Old 01-17-2011, 10:57 PM   #7 (permalink)
uibalnme's Avatar
You have a gen 3 though, so possibly different results?...
gen3 or gen4, same engine. The only real difference would be the ignition system. Distributor vs, coil pack. Also, I'm in California, so my car has 2 catalytic converters. That would diminish the sound quite a bit. Even so, it's still somewhat loud with this muffler.
Face the facts. It's an aftermarket "performance" muffler. It is NOT going to be OEM quite, which is what I thought you were looking for.
Old 01-18-2011, 11:33 AM   #8 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Go with OEM if you want OEM quiet. Check here. They have parts pretty cheap for both OEM replacements and aftermarket.
http://www.carpartswholesale.com/v5/...7065&submodel=
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 01-19-2011, 01:36 PM   #9 (permalink)
View camry6's Photo Gallery
If your Camry exhaust is all original, the complete exhaust system is stainless steel, except for the flanges that join the pipes and components together. The best way to fix this is to go to a muffler shop and have them cut out the rusty flanges and patch in a small section of stainless exhaust pipe and have it welded in. If you replace any part of your exhaust system with aluminized steel pipe or muffler, you will be replacing those sections over and over.
1993 Toyota Camry V6 LE (200 HP, 195 ft/lbs tweaked) , 430,000 km's.
2002 Lexus GS 430 V8 VVT-i (300 HP, 325 ft/lbs) Luxury with Mark Levinson , 156,000 km's
2006 Lexus ES 330 V6 VVT-i (225 HP, 250 ft/lbs) Premium Luxury, Sport, Navigation with Mark Levinson , 140,000 km's
camry6 is offline   Reply With Quote
Old 01-20-2011, 07:31 PM   #10 (permalink)
werkit217's Avatar
Went to the muffler shop close to my house, $70 for the replacement resonator and pipe. Now I can enjoy hearing nothing from my car, except for my concert quality car audio .
Thanks everyone for you input ...
Old 05-06-2011, 10:02 PM   #11 (permalink)
View Ryan01le's Photo Gallery
i know this thread kind of ended, and this is a slightly different question than whaty was originally being discussed but ive been wantin to do a new exhaust set up. i wanna remove resonator and do a dual exhaust. yes its the I4 but i think itd be cool. any suggestions? maybe even some rude remarks?
Ryan01le is offline   Reply With Quote
Old 05-07-2011, 09:02 AM   #12 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Get a muffler with dual tips. Trying to do a somewhat dual exhaust ( y pipe after cat) will sound like a lawnmower in distress.
But straight pipe after the cat with just a muffler shouldn't sound horrible. Delete the air intake resonator and throw a cone filter on the end of the intake pipe and that'll make it sound good for only 25$.
But theres no way to make it sound like a v8, i think thats what your trying to ask.
carsrus is offline   Reply With Quote
Old 05-07-2011, 11:43 AM   #13 (permalink)
View ShawnD93Toy's Photo Gallery
I just had one of these installed on my car
http://www.apexhaust.com/index.php/p...bo_mufflers/C7
the shop built a catback for me with no resonator and it isn't to loud, but I have a 3vz-fe. With a resonator in it would probably be really quiet.
ShawnD93Toy is offline   Reply With Quote
Old 05-07-2011, 12:27 PM   #14 (permalink)
BAM! It's SPAM!!!
prjkt_c4mry's Avatar
View prjkt_c4mry's Photo Gallery
I have the TRD axle back exhaust and it's just barely louder than OEM when I keep the RPMs under 2k. It only sounds louder than stock around 2.5k and up.
'99 Camry XLE V6
"Sex should be like a riced Civic; Slow, obscene, and loud enough for the neighbors to hear."
prjkt_c4mry is online now   Reply With Quote
Old 05-07-2011, 06:08 PM   #15 (permalink)
no i dont wanna do a hillbilly hot air intake. and how do u kno itd sound like a lawn mower in distress? i dont like twin tip mufflers, they dont sound any different
