i took mine to a trany shop for a free diognostic, and they told me it was nothing electrical or the tranny itself they said it was either the front main pump going out of it was something not hooked up right, like the passing gear kick down cable, which i am having a hard time finding. it may be off set and not triggering smooth rpm execution of pressure. which results in what they said "your having low pressure" which wasnt all bad but i need a way to find out "whare" it is occuring.
let me know what you do or whare you take it and what they say, id call a tranny place. make sure its not electrical cuz they can run the dio and tell you you if you have a bad solenoid or connection.
or if its a bad part. if not, then keep in touch and when i find out whare to find my issue you might be able to find out whare yours is.
kasper
______________________________________
1997 toyota camry 5sfe 2.2l, automatic tranny, jdm import swap out. 101k tranny, 189k on body. 58k on engine. cv swap advice?
