Wiper problems! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2011, 02:37 PM   #1 (permalink)
View Lurch_13's Photo Gallery
Wiper problems!
The windshield wipers on my gf's 96' Camry are messed up. If they move they do so very slowly. Mostly not at all. I replaced the motor but the wipers aren't even moving. I checked to see if it worked before in stalled the linkage. Also to make sure it was "home".
Reading the haynes manual it mentions a wiper motor relay. I suspect its to blame. But don't know where it is on the car or the proper way to check it.
Any one know where the wiper relay is on a 96 camry? Or have another idea what the problem is?
Any help would be much appreciated. Thanks in advance.
Lurch_13 is offline   Reply With Quote
Old 01-17-2011, 03:38 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
There is no wiper relay for 92-96 camry Sedans/coupes. There is a Relay on the Wagons only. There is a 20A Fuse behind the coin tray (Fuse 5).
Theres only a few things that would cause your wipers to not work
1. Wiper Fuse (Listed above)
2. wiper Switch
3. Wiper Motor
4. Wiring harness
I would suspect fuse, switch, or motor.
If everything is working, or within spec repair the wiring harness
The Following User Says Thank You to Mister_Perkins For This Useful Post:
Lurch_13 (01-17-2011)
Old 01-17-2011, 04:53 PM   #3 (permalink)
Thanks man. As soon as I get my volt meter (not home now) I'll check all that.
Old 01-17-2011, 06:48 PM   #4 (permalink)
Gameroom cash: $127997
View jordan7831's Photo Gallery
Something similar happened to my carmy, I ended up squirting WD-40 on all the linkages and it worked like a charm. Try this, take off the wiper arm completely off. And underneath you will see a washer, sometimes this gets seized and causes the malfunction.
jordan7831 is offline   Reply With Quote
Old 01-17-2011, 07:07 PM   #5 (permalink)
^^ Try that as well. thats a very good suggestion! I would actually try that before testing the electronics
Old 01-17-2011, 09:03 PM   #6 (permalink)
Ya it would be a smart idea to try this before you rip apart your wiper arm assembly. Most likely its just corroded from all the salt and grime (assuming you live in a country that has a rough climate)
Old 01-17-2011, 10:43 PM   #7 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
