1997 LE 4Cyl - Check Engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2011, 12:09 PM   #1 (permalink)
View anubis93611's Photo Gallery
Hey all, just picked up a 1997 4 cyl Camry for my son, first car. 100k miles in great shape. However, it keeps tripping the check engine light. MY buddy had a diagnostic computer to use for a while and i was able to see the codes and replaced the faulty parts. One was the #1 O2 sensor, and thermastat. It said somthing about the heater loop closed. I thought we had fixed the problem until it came time to smog it. California BTW. The check engine light came on.. Mech was cool and did not charge me, but told me to replace the #1 O2 sensor... which was brand new.. I returned it and put a Bosch in.
After removing the battery cable, and resetting the light.. It runs great, seems to be good, until about 30 mins when its good and warmed up, the light comes back on. But i have no diagnostic computer to check the code. Cant get the one we used again... What else could it be? could it be the O2 sensor? Mech said the computer might be bad, and was willing to charge me 1500 for a computer... i heard that the computer might need to be flashed? i need to codekey or somthing to check the code.... PLEASE HELP!
anubis93611 is offline   Reply With Quote
Old 01-18-2011, 12:12 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
What were the codes from the first analysis? You may have replaced the wrong 02 sensor.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 01-18-2011, 12:19 PM   #3 (permalink)
I dont remember the exact code, but im sure it was the #1 O2 sensor... even the Mech confirmed it. he said the computer was bad, or needed to be reflashed.. i need to plug it back in to some one with a computer... but, no one here in california does it for free...
Old 01-18-2011, 12:20 PM   #4 (permalink)
Also replaced to Air/Fuel ratio sensor.....
Old 01-18-2011, 12:21 PM   #5 (permalink)
Chemist at Chevron
Gameroom cash: $315485
View bdy0003's Photo Gallery
Did you try autozone?
95 Camry LE I4 195k
bdy0003 is online now   Reply With Quote
Old 01-18-2011, 12:24 PM   #6 (permalink)
Did you replace the sensor on the firwall side or the one in front as you look in?
Old 01-18-2011, 12:25 PM   #7 (permalink)
No free AutoZone diagnostic in California...
Old 01-18-2011, 12:26 PM   #8 (permalink)
Right out of the exaust manifold. Front of engine.
Old 01-18-2011, 12:34 PM   #9 (permalink)
Sorry, I was thinking 6 cylinder. You are correct. You can buy a cheap code reader for under $50. Try Harbor Freight. We really can't do much without the code.
Old 01-18-2011, 12:35 PM   #10 (permalink)
ok, im all over it... ill get it scanned one way or the other... and get back ASAP!
Thanks..
Old 01-18-2011, 01:22 PM   #11 (permalink)
P0135 - Front Oxygen Sensor heater circuit fault..
Thats the devil code..
Old 01-18-2011, 01:54 PM   #12 (permalink)
View 97ToyCar's Photo Gallery
The front O2 sensor's internal preheater is dead. Replace it with either a Toyota or Nippondenso sensor, even NGK will do fine. DON'T buy the Bosch, it's junk, and you'll wished you hadn't if you do. Make sure you get the OEM style, so it's plug and play. Disconnect the battery for 5 minutes after you are done to reset the ECU. Done.
97ToyCar is offline   Reply With Quote
Old 01-18-2011, 02:06 PM   #13 (permalink)
View hzt30's Photo Gallery
I agree about Bosch O2 sensors. Conventional wisdom is that Toyota's do not like Bosch O2 sensors. I used Denso in my Camry and never a problem.
hzt30 is offline   Reply With Quote
Old 01-18-2011, 03:11 PM   #14 (permalink)
Of course, Bosch is what it installed... no wonder it doesnt work... ill return it... the problem is finding one in stock that will snap in.. the plug seems to differ quite a bit..
OK, ill try n find one of the ones listed... expensive part.... 180 bucks.
Old 01-18-2011, 03:43 PM   #15 (permalink)
View dudutzu's Photo Gallery
Amazon Amazon
$64 shipped
dudutzu is offline   Reply With Quote
