As said, if it's a slow leak then you can keep an eye on it and refill regularly with Dexron III type ATF. Walmart's dino SuperTech is a good value.
Otherwise, try Lucas Power Steering Stop Leak:
http://www.lucasoil.com/products/dis...tid=9&loc=show
When you get that new car, try to siphon out the reservoir and refill with new fluid at least every other oil change. This will help the seals last by removing the abrasive wear particles from the system.
Originally Posted by twocamrys
When I went for an oil change a few months ago, my mechanic said that my car was a little low on power steering fluid. I was told that my power steering pump and rack would need to be replaced. During the past two months, the level of power steering fluid in my reservoir hasn't changed much and I am not hearing any strange noises when turning or driving. I noticed a small amount of power steering fluid on the floor of the garage though so I think the mechanic is right about the leak.
Are slow power steering leaks common on 4th generation Camrys? If my power steering pump and rack do need to be replaced, will I damage anything else in the car if I just let this leak go until it gets worse or starts making noises when turning? Would it help to add some Stop Leak or should this only be used with larger power steering leaks? I plan on getting a newer car in a few months so I'd really don't want to spend over $1,000 to fix it right now.
