01 Solara Manual Tranny Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2011, 06:48 PM   #1 (permalink)
View jobodizo's Photo Gallery
Hey Everybody,
I've owned my 01 Solara, V6, 5spd for about 1.5yrs now and I can't seem to get rid of a persistent nagging problem:
Since I've owned the car, I've had problems with rough shifting. If I'm doing a rolling stop and shift into first, the car often fights me or clunks into place. The same goes for ALL gears if it's especially cold outside. More often than anything, I will get an occasional gear grind (light, more feel through the shifter than hear) going into 3rd or 4th gear.
All of this started shortly after I got the car. Initially it was a clutch pedal that was spongy near the floor. Bled the slave and travel seemed to equalize. I thought maybe the issues were wearing synchros, so I drained the gear box and filled it with ridiculously expensive Royal Purple. Unfortunately that seemed to help very little, but maybe a little.
Newest symptoms: never seems to do it when I'm driving aggressively. Never seems to do it when I kick the clutch pedal to the floor instead of pushing. I've checked the master and slave cylinders: no fluid on/around slave, maybe a drop under the master but the level is still filled to the brim and I haven't added anything for ~a year.
Any help would be appreciated...I'd HATE to have to pay somebody to "diagnose" it by replacing everything.
jobodizo is offline   Reply With Quote
Old 01-18-2011, 07:04 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
what fluid the transmission was/is running on? how often was the oil changed?
Old 01-18-2011, 07:10 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
So when you stomp on the pedal everything worked better?
I'd check the clutch hydraulic system first then. The brake fluid is at the max mark, not literally to the brim, right?
Old 01-18-2011, 07:17 PM   #4 (permalink)
Lord of the Sith
Gothmog3VZ's Avatar
Gameroom cash: $391902
iTrader Score: 6 reviews
View Gothmog3VZ's Photo Gallery
first gear clunking is because 1st is unsynchronized - I noticed the same thing, but I just rev-match when I need to engine brake.
As for the feel when it's cold outside, it's normal. Your synchros are a lot less "grippy" when cold, and the cables are much stiffer, so the feel will be odd. should go away once the car has properly warmed up (I noticed it yesterday going to the pump - car sat outside all day, it was -23*).
gear grind is usually related to a clutch that's not fully disengaged, so check the hydraulics, as stated
1993 Toyota Camry 3VZ 5-Speed
(Beige Beluga)
1989 Toyota MR2 3S-GTE 5-Speed (Din)
Need performance parts?
Shoot me a PM, I'll see what I can do
Gothmog3VZ is offline   Reply With Quote
Old 01-18-2011, 09:02 PM   #5 (permalink)
hehehe E153 should be fully synchronized. Yes, they do like to turn into non-synchronized transmissions later.
Old 01-18-2011, 09:15 PM   #6 (permalink)
Camry Expert/MR2 JR Xpert
jtex2717's Avatar
Gameroom cash: $272115
View jtex2717's Photo Gallery
try Redline Shockproof Lightweight for tranny fluid. The MR2 guys swear by this stuff and it actually works. It should fix all of ur symptoms...
Finally Red MKII MR2 5s & Metallic Blue 96 Cam 1MZ
Watch out for the build thread!!!
IM BAAAAAACK!!!!!!!
jtex2717 is offline   Reply With Quote
The Following 2 Users Say Thank You to jtex2717 For This Useful Post:
doozergreengrass (01-18-2011), LynchburgCSI (01-18-2011)
Old 01-19-2011, 05:27 PM   #7 (permalink)
Thanks for all of the replies. To answer the questions above:
When I say to the brim, I mean to the max fill line. The cold is understandable, I'll start giving it more time to warm up in the morning. Might wait on the Shockproof...I'm in the midwest and the temp's not THAT bad. The Purple was 75-90 I think, whatever the manual specified in the back...before 1yr ago I can't say.
Is there a way to check the hydraulics individually before I start replacing? You guys'll have to forgive me, but I'm used to 40+ yo Fords w/ springs. Obviously the slave moving with the pedal I've got...anything beyond that?
I should also mention that back in the summer the buzzing seemed to get worse as I got closer to home in the afternoons (hotter in the day and just came off the interstate).
Old 01-19-2011, 07:47 PM   #8 (permalink)
75W90 should be just fine. Or try Valvoline's SynPower fully synthetic 75W-90 gear oil.
If there is no air in the hydraulic system, and the piston cups aren't leaking, then I suspect improper clutch release being a reason for the gear clashes. This can be an adjustment problem or the clutch disc is wearing thin, causing the diaphragm spring to move out toward the slave piston. I don't know for sure, just guessing.
But since you said stomping on the pedal makes it work fine, it's like stomping on failing brakes trying to get some pressure. Just my 2 cents.
